Old 12-08-2016, 01:12 PM   #1
davepl
davepl's Avatar
How to crimp the end on a parking brake cable
Anyone know? I have a swedge tool (big bolt-cutter looking crimping tool) but when I crimped a standard aluminum ferrule on there, it got ripped off the first time I hit the park brake pedal. So that didn't work.
Are there steel or iron ferrules that actually work, or is that the wrong approach?
Even tried to TIG one on and spike it, no luck.
Has anyone successfully created their own custom-length parking brake cable?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-08-2016, 01:39 PM   #2
jeffahart
jeffahart's Avatar
Re: How to crimp the end on a parking brake cable
Dave I know you have a super clean ride and are probably looking for an OEM type look and function, but... here's what I did. And it ain't going no where. It's solid and I'm leaving it like this. I am merciless and leg press my parking brake. Simple garage spring wire rope clips/clamps. You could do this as an interim solution until you find someone with a good ferrulling tool.
White K20
jeffahart is offline   Reply With Quote
Old 12-08-2016, 01:47 PM   #3
davepl
davepl's Avatar
Not stock looking to be sure, but hardcore enough that I like it.... thanks!
Old 12-08-2016, 02:22 PM   #4
jeffahart
jeffahart's Avatar
When I was a kid, eighteen, I worked for a company called Swinerton and Wallberg. I worked on a few high rise towers. They used that type of clamp on 1/2" safety cables. Only two clamps. We used to hang from the side of the buildings using the cables, to hang concrete forms. Whenever I see this type of clamp I think of hanging from that building over Wilshire Blvd, what a hoot that was!
The clamps are solid, and once again... Ugly Works!
White K20
Old 12-08-2016, 09:56 PM   #5
firedemon
have you tried soldering them when I do bike cables I use plumbing solder then crimp after it cools . i never tried on an ebrake cable so I'm unsure if it will work but might be worth a try .
firedemon is offline   Reply With Quote
