Old 12-08-2016, 01:18 PM   #1
Ken O.
Speedometer cable going bad?
So the speedometer on my 67 GMC started making some noise above about 35 mph a couple weeks ago. When it does this the needle starts wavering up & down, (usually up to about 50 or so) Well this morning on the way to work it really started getting loud and started flopping from 0-120 or so. I assume this is the speedometer cable going bad, correct? When it happened in other vehicles it just stopped working period. Never had one go nuts and start flopping around before. haha!
Ken O. is offline   Reply With Quote
Old 12-08-2016, 01:36 PM   #2
Toms67
Toms67's Avatar
Re: Speedometer cable going bad?
If if the internal cable isn't frayed yet. Unhook behind the gauge. And put Lube down inside the cable. It has worked for me before. Good luck.
Toms67 is offline   Reply With Quote
Old 12-08-2016, 01:36 PM   #3
truckster
truckster's Avatar
The cable has one plastic end, and sometimes that breaks and then the speedometer stops working. It sounds like your cable is binding. You can pull it out, clean it, and lube it with white lithium grease and it will probably work for another 40+ years.
truckster is offline   Reply With Quote
Old 12-08-2016, 01:44 PM   #4
Ken O.
Thanks guys, I'll see if some lithium grease will help. Can't hurt, that's for sure. I had it off when I changed the dash face out early this spring and it looked ok then. Of course it doesn't decide to do this until it's 5* outside... sigh...
Old 12-08-2016, 02:01 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Seems like I read on this board that graphite works better..... but all I ever used was white lithium grease and it worked fine for me.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-08-2016, 02:57 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
If graphite gets wet it turns into a thick gummy mess. I wouldn't use it....
LockDoc
Leon
Old 12-08-2016, 03:30 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^ Good to know.... thanks, Leon!
- Mike -
RIP El Jay
Old 12-08-2016, 05:00 PM   #8
Ken O.
LockDoc
Interesting tidbit I never knew....
Old 12-08-2016, 05:02 PM   #9
truckster
truckster's Avatar
Just to be clear, the best way is to pull the entire cable out, clean it as well as you can, and then lube the entire cable lightly with white lithium grease. Just putting lube down the end of the cable may help for a while, but it's not the best solution.
Old 12-08-2016, 07:52 PM   #10
LockDoc
LockDoc's Avatar
No problem. The reason I know is because I have disassembled many automotive door and trunk lock cylinders that had graphite used in them and they were really bad inside. It was like a thick paste, and in a few of them it had hardened into a semi-solid chunk....
LockDoc
Leon
Old 12-09-2016, 06:33 PM   #11
joeydurango
joeydurango's Avatar
They actually do this worse in the cold - the cable binds more easily, I suppose due to what lube (or dirt?) that is in there thickening in the cold. Both of my K10's speedos worked fine in the summer and bounced more in the winter, although the current truck is much better overall.
If it were 70* tomorrow, I bet your speedometer would work perfectly again.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 12-09-2016, 07:12 PM   #12
BILT4ME
I pull the cable from behind the odometer, spray it with brake cleaner multiple times to get it clean. let it dry (just a few minutes) then put it in a gallon freezer Ziploc bag. Then I put in some white lithium grease and smear it around real well.
Then I put white lith grease into the hole of the speedo cable housing and try to push it as far as I can. If I have it in a gun, I wil place 8-10 pumps in there. Then I run the cable in and out about 30 times, making sure the first end in has fresh grease on it each time. (Trying to push the grease to the bottom end)
Then I push the cable in from the bag until it is all the way in. The Ziploc helps keep my hands and the interior of the truck clean.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
