![]() Join Date: Aug 2016
SB400 Accessory Holes?
I understand the SB400 to be the same block as the SB350... Blah, blah... However, I have acquired the front serpentine setup from a '99 5.7 and would like help to confirm it will bolt on before buying all new accessories and tearing the front of the engine off of my SB400.
Thanks, Boudy |
Re: SB400 Accessory Holes?
Not sure if a 3rd generation front serpentine setup will work but a 2nd generation V8 front serpentine setup Will work and will pretty much bolt right on. I did this with mine and am really happy with mine.IMHO if its not to late I would try to get the 2nd generation one. I believe they are still readily available in wrecking yards.If you do go this route send ma a PM and i'll help ya out.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
The diagram show an acc drive from a 96-00 5.7 [old style ] small block and you should have no problems with it. The drive from those years placed the Alt on the pass side and the A/C compressor on the drivers. The 1st gen serp setup however placed the A/C [r4 type] compressor on the pass side and the Alt on the drivers above the power steering pump. either will work for you it is just a matter of visual and what you want. Jim
Should work just fine as long as you have the three bolt holes in the heads.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
Beats the hell out of me! However what I think I can say is that the system you are using appears to be what was primarily used on the L05 5.7 built from 1988 to 1996. The ones I have are for the L31 5.7 (Vortec) built from 1996 to 2002. Both the L05 and L31 were Gen 1 just the L31 was used in trucks while the LT series Gen 2 was used in the F-Bodies.
I think... Sure somebody knows definitively. Boudy Last edited by TXBoudy; 12-08-2016 at 10:29 PM. Reason: Yeah, what Jim said! |
I've got AFR 1034's with 3 holes.
Boudy |
