Moderator
![]() ![]() Join Date: Aug 2011
Arm Rest Door Panel Space
Looking at the interior door panel, once you attach it to the inner door there are two cage nuts that you screw the arm rest to. Is there supposed to be a spacer in there between the door and the inner door panel?
![]() Join Date: Aug 2013
Re: Arm Rest Door Panel Space
the only spacer/eschution i know of is between the inner panel and the window crank and inside door latch. there is also the gasket that goes between the inner panel and door, i guess it can act as a spacer.
Moderator
Side view? Maybe I'm over-thinking this.
maybe this will help, its the template from the armrest.
Moderator
That's not going to flex?
Having built my truck from a "box-o-parts" I'm not sure.
![]() ![]() Join Date: Apr 2012
Theres no spacer. Ive done this several time 1959 through 1967. just the arm rest , screws and cage nuts.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Moderator
No Spacer Aye.
Thank you.
Just put armrests on my '66. No spacers, just screws directly into cage nuts. I wondered the same thing at first, but it seems to fit just fine.
X 3.
I used a pattern found here somewhere but found them off a bit. Next time to get the holes spot on I would draw my own lines with panel off and on. A welcome addition to the truck. |
#11 | |
Moderator
![]() Thanks everyone.
