Old 12-08-2016, 11:21 PM   #1
AASmedic
AASmedic's Avatar
STICKY Tach
Good evening all,
I just finished the install of my new Tach/Vac cluster and everything was working great. I revved the engine a couple of times and noticed that the Tach needle was stuck around the 2500 rpm mark. I tapped on the lens and it went back down but it seems to do it regularly now. Suggestions???
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 12-09-2016, 06:51 PM   #2
joeydurango
joeydurango's Avatar
Re: STICKY Tach
Your problem sounds somewhat similar to mine; see thread from a couple months back: http://67-72chevytrucks.com/vboard/s...d.php?t=720688
Haven't figured anything new out since. I just know that generally when I start it up, the tach is dead, then it will begin "highpointing" and sticking like yours is, and once the truck is warmed up fully and we're on the way somewhere the tach decides to work properly. I'll dig deeper if it eventually stops working altogether.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 12-09-2016, 07:01 PM   #3
AASmedic
AASmedic's Avatar
Re: STICKY Tach
Thanks for the info.
Old 12-10-2016, 12:55 AM   #4
trucksntrains
Re: STICKY Tach
I had a tach that would always get stuck around 1800. sometimes it would go down with tapping, sometimes it wouldn't. When I had the dash apart to clean it up, I found that the needle was slightly bent upwards contacting the center. I gently pushed on the needle to bend it down enough where it wouldn't catch on the center and had not had a problem since then.
blue 68 c-10 work in progress
yellow/white 72 Cheyene Sold!
Green 71 Vw Bug
trucksntrains is offline   Reply With Quote
Old 12-10-2016, 12:57 AM   #5
AASmedic
AASmedic's Avatar
Re: STICKY Tach
That's the exact problem I am having. It seemed free when I installed it but it's right around the 18-20 mark. Thanks for the comment.
