Old 12-09-2016, 01:39 AM   #1
allaboutchevelles
allaboutchevelles's Avatar
65c10 adjustable panhard bar?
Has anyone used the POL 65-72 C10 adjustable panhard bar from ebay for 52$
How is the quality? did it work well?
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 12-09-2016, 04:07 AM   #2
Kenfuzed
Kenfuzed's Avatar
Re: 65c10 adjustable panhard bar?
I actually just picked up one from POL in Corona today. I'll probably get around to installing it over the weekend when I do my axle swap. The quality looks really good and appears like it will be much easier to adjust.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-09-2016, 08:54 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I have one installed on my build. Long POL unit. https://www.performanceonline.com/19...-Bar-Trac-Bar/
Old 12-09-2016, 09:14 AM   #4
PGSigns
PGSigns's Avatar
I have gone to the long bar that runs to the trailing arm on both my trucks and like it more than the short one. It goes through less side shift as it travels and the lower roll center seems to help the handling. I do use my truck a lot as a truck so these features work better for me.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-09-2016, 09:41 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I am also going to the long bar, probably the porter bolt one. I have the stock replacement adjustable on now and need something else especially when I run lower than stock...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-09-2016, 11:13 AM   #6
LVPhotos
LVPhotos's Avatar
Here's the Porterbuilt one for reference on the '62
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-09-2016, 01:19 PM   #7
allaboutchevelles
I'm wondering why 64 had a 27" bar and 65 and 66 had the 24" bar? I lowered my truck 4 or 5 inches cant remember in the back with springs. wouldn't lowering the truck make the bar need to be shorter?
Old 12-09-2016, 01:35 PM   #8
Clyde65
Clyde65's Avatar
Depends where it's connected at the axle I believe.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-09-2016, 03:55 PM   #9
Kenfuzed
Kenfuzed's Avatar
Mine is the shorter one on my 66. Already have it lowered 5" and the stock bar is only showing centering to be off by 1/2" so I picked up the adjustable version from POL so I can fine tune it some. It has driven fine for a while now without the adjustment but since I'm getting new wheels soon I figured it was time to get it set correct.
Regarding the original question, the quality looks good and these are their new larger diameter bar with the double adjustment ends so you don't have to take one end off to adjust... a plus for me since I'm lazy
Enjoying the ride!
Old 12-11-2016, 09:12 PM   #10
allaboutchevelles
Thanks Kenfuzed. I think I'm going to go ahead and get that one also. I haven't measured mine to see how far off it is.
Old 12-11-2016, 10:14 PM   #11
68c10airstream
68c10airstream's Avatar
I'm running the porter built one and can say for sure the ride was less bouncy. Nice heim joints and the quality of welds and grade 8 fasteners are top shelf. My 68 c10 is 4" lowered ece springs and 1" blocks, Monroe sense-a-trac shocks, shock relocators.
68c10airstream is offline   Reply With Quote
