Old 12-09-2016, 08:35 AM   #1
walkerb
walkerb's Avatar
1986 K30- replacing hydro boost- Pedal Code?
So my 86 K30 srw 3+3 has a leaking hydro to master leak. Leaking for way too long now.
Rock auto lists rebuilt units but lists 2 different pedal codes.
Question- what's a pedal code and how do I find out what my pedal code is?
Thanks for any info!
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 12-09-2016, 11:52 AM   #2
100%Chevy
Re: 1986 K30- replacing hydro boost- Pedal Code?
I don't know about the pedal code.
I have 2,C-30's,An 82 and a 86.
Both have hydroboost and use different length push rods between the hydroboost unit and master cylinder.This is the difference in the depth of the hole in the master.
I understand the brake rod is mounted different on the pedal for hydroboost than on regular or vacuum assist brake pedals.
Mike.
100%Chevy is offline   Reply With Quote
Old 12-10-2016, 10:26 AM   #3
walkerb
walkerb's Avatar
Mike, can the rods be swapped like on the boosters? This will be the first time messing with a hydroboost system for me.
Old 12-10-2016, 11:29 AM   #4
100%Chevy
The difference in the rods is because of the different master cylinders.
Far as I know,the hydroboost units are the same.
It works!
Mike.
