Old 12-09-2016, 10:51 AM   #1
Dave K.
Dave K.'s Avatar
Pics K10s with 15x6 Rims and Larger Tires
Just trying to get a feel for the "look" before I go down the road of original sized rims and tires. Would like to see what the largest tire (both diameter and width) I could put on these rims would be and how it would look. Assume stock ride height, want a proportional look I guess you might say.
Thanks, Dave.
Dave K. is offline   Reply With Quote
Old 12-09-2016, 03:29 PM   #2
TwoFiftyShifter
Re: Pics K10s with 15x6 Rims and Larger Tires
With a 6" rim, I think a 30x9.50x15 would be the largest.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-09-2016, 04:55 PM   #3
71threequarterton
71threequarterton's Avatar
This is on a truck I was thinking of buying. It's a 32/12.5/15 but I'm not certain the wheels are stock. They look like the stock rallies.
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
71threequarterton is offline   Reply With Quote
Old 12-09-2016, 06:19 PM   #4
joeydurango
joeydurango's Avatar
Rally wheels weren't ever stock on 67-72 trucks.
Could be wrong but I don't think rally wheels came in a 6" either...
In any case, definitely don't run 12"-wide tires on a 6" rim. I'd guess that rally in the photo is 8-10" if that's a 12" tire.
OP, you might know all this but just wanted to clarify. EDIT: Also, OP, you should be able to squeeze 33" tires into a stock-height truck, assuming your springs aren't super-saggy... I don't know whether anyone manufactures tires in a 33" size narrow enough to work on your 6" rim though. I'm almost certain I've seen 10.5" tires on 6" rims, although they look pretty "bulgy", not ideal. 33x10.5 R15 is getting difficult to find anyway.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 12-09-2016, 06:23 PM   #5
TwoFiftyShifter
15x6 is tough. 235/75r15 is the best fit, but that is a 28" tire. Our minds nowadays are trained to think that's too small a tire for a 4x4. If you really like that look, I'd see if you can find a plain 16" 6lug steel wheel. That leaves you with the option of a 235/85/16 which is a nice 31-32" tire.
1982 K10 SWB
Old 12-09-2016, 06:23 PM   #6
erikoj
I have 33" BFG mud tires on stock 15x8 rims, it does have a lift kit however
erikoj is offline   Reply With Quote
Old 12-09-2016, 06:31 PM   #7
71threequarterton
Didn't mean to post any misleading info - those are actually 32/11.5/15 and by stock I meant factory, not for that year but not aftermarket - I could be wrong though. I spoke to a couple of folks over email and phone when I was considering buying that truck and they didn't seem to know exactly what the specs were. They had it advertised as "mild lift with 35s" and you can see right there in the picture, if you zoom in, that they are 32"s.
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
Old 12-09-2016, 06:38 PM   #8
joeydurango
No worries. Just didn't want confusion to set in on that one!
OP, I ended up going with 15x8 steelies (stock-look wheels) because I wanted to run larger tires than ideal on 6" rims. If you're changing the tires from the tiny stockers anyway, it isn't as if the truck is totally original, after all - so changing the rims to wider ones that look the same as stock made sense to me. I'm running 32x11.5 R15 on 15x8 rims:
Old 12-09-2016, 07:11 PM   #9
Dave K.
Dave K.'s Avatar
Thanks guys, appreciate the feedback. Especially helpful to do some thinking while here in the middle of the Sahara! I guess I keep coming back to the 15X8 look after seeing Joeydurango's truck. Perhaps 15 x 8s with 31" tires would be the optimal fit for stock ride height....
Old 12-09-2016, 09:41 PM   #10
Oscar the grouch
Oscar the grouch's Avatar
I know you were looking for 15's but I'm running 16 x6 rims with a 235 85r16 tire which is like 31.5 in.tall to give you an idea
1970 chevy k10 305/4 speed
Oscar the grouch is offline   Reply With Quote
Old 12-09-2016, 11:34 PM   #11
palallin
I don't have a recent pic handy, but I run 31" (LT295-75R15) on the stock 6". Have had them for years, no tire troubles.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 12-10-2016, 08:38 AM   #12
52napco
Here's 31x10.50 on 15x8 cucv blazers wheels and 255/85-16's on 16x7 wheels on K20
52napco is offline   Reply With Quote
Old 12-10-2016, 07:49 PM   #13
Dave K.
Dave K.'s Avatar
Thanks everyone for your input again here. I've been hemming and hawing on this for some time but I really like the look of the blue truck as well the green one with the 16" rims. No doubt I will go with hubcaps as I like the look. I'm really leaning towards the 16" look, wheels aren't as deep but you've got the beefier tires/rims on it which fill the large wheel wells better than the 15-6" with smaller tires. I will probably go with this look if I can find some 16 x 6 6-lugs. If not then for sure the CUCV look. I think my 50th Anniv Shortbed would look good with white hubcaps or even the others even though it won't be original.... can always pop them off if needed.... Many thanks once again. Dave.
