12-09-2016, 06:07 PM | #1 |
69 Grand Prix stock rear sway bar
Has anyone used a stock 69' Grand Prix sway bar on a 67-72? I looked at one today and measured it. I think it would bolt up to the trailing arms easy.
12-09-2016, 08:25 PM | #2 |
Re: 69 Grand Prix stock rear sway bar
Now I hope it works for you but how many more could be out there? There wasn't a lot of those parts to begin with. I hope it does work well for you. I think the second gen Monte might be the same like 73-77. Now those might be a little easier to find
12-10-2016, 09:21 AM | #3 |
Six in a row makes it go...
Addco lists the same part number for GP and A-body of that year. If true, and if you can make it fit, you should have your choice of aftermarket A-body bars, of which there are many.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
12-10-2016, 09:59 AM | #4 |
I have been researching and it looks like both A and G body sway bars will work. Looks like an easy bolt on without a lot of mods. Time to go the local yard and pick one or two.
