12-09-2016, 07:10 PM | #1 |
Anyone using stock radiator on LS swap?
As title states...anyone using stock 67-72 radiator on their LS swap?
If so, what fan you using? what hoses are you using? what shroud you using? Thanks!
Jimmy Hoelzel |
12-09-2016, 07:26 PM | #2 | |
Re: Anyone using stock radiator on LS swap?
I used an electric fan from a ford taurus. |
12-09-2016, 08:21 PM | #3 | |
12-09-2016, 09:29 PM | #4 |
I used the stock rad, engine driven fan, stock small block shroud.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
12-10-2016, 09:27 PM | #5 |
stock 4 row with dual Spal fans and a custome made shroud that also houses my intercooler heat exchanger.
12-11-2016, 11:01 PM | #6 |
Thanks guys!!!
Jimmy Hoelzel |
12-12-2016, 08:22 AM | #7 |
I'm running a stock 4 core radiator with a 2008 5.3l swap with dual dodge Stratus fans from the JY. It took a little work figuring out the right thermostat (180 degree) but the combination is doing VERY well.
