12-09-2016, 11:24 PM | #1 |
parts resource
Hey guys, I got a run down 7 grande sierra K10 and I was wondering what out of it I can swap to my 70 K2500. Recent the brakes went out on the 70, not sure if it was a line or the master, but there is zero pressure at all. So, either A: I was running off only one circuit, or B, the master is gone. Moral of the story is that the stock setup was a manual master, and the 77 has a vac booster and good master. Will the master bolt up and work with the all around drum brakes or should I look at some other way of doing it?
Thanks, Austin |
12-09-2016, 11:53 PM | #2 |
Re: parts resource
Hey vintagefarmer ...
to the forums and from Ohio I don't have an answer but here is a bump for you ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-10-2016, 12:36 AM | #3 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: parts resource
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
12-10-2016, 12:46 AM | #4 | |
Re: parts resource
12-10-2016, 01:44 AM | #5 |
Re: parts resource
Yes they do. I run power drum/drum on my 70. You can still get new master cylinders at most auto parts stores, and they're not too expensive. So if you wanted to convert yours to disc, it wouldn't break you.
12-10-2016, 11:49 AM | #6 |
Re: parts resource
Alright, awesome. Now I just need to get the new master and such. Would it be a direct bolt on if I went to O'riellys and bought a power brake master?
12-11-2016, 12:09 AM | #7 |
Re: parts resource
You can use a manual master cylinder and add the booster, but you will need the pushrod for power brakes. The stock manual lines will also work. Just make sure to bench bleed the master cylinder before you install it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-02-2017, 12:18 PM | #8 |
Re: parts resource
do you have the part number for the push rod?
01-02-2017, 05:24 PM | #9 |
Re: parts resource
i also have the ability to pick up an old c50 parts truck that might be of use. does anyone know if and what parts interchange? its of the same vintage i believe
