12-10-2016, 07:31 PM | #1 |
83 fuel tank leak question
like always i wait until the last minute .. put the blade on because we have snow coming . filled with fuel . truck sat all summer and now have a leak . I have a plastic tank on a bare frame that I can get to easily . It only has two lines off the top . I would guess supply and return ? The one on the truck now has three lines . Can I make the plastic tank work ? Have a couple drives to blade and not sure if it will run off the passenger tank .
Thank you |
12-10-2016, 07:49 PM | #2 |
Re: 83 fuel tank leak question
The lines are part of the sender?? Use your old sender in the new tank?? Welcome aboard!!
12-10-2016, 09:49 PM | #3 |
Check the filler hose. Might be leaking since you noticed during a fill up
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
12-10-2016, 10:01 PM | #4 |
low 69 - I could not be that lucky ! The filler end and neck area look dry . The front end ,under cab , is where it seems to be leaking . I would use the passenger tank for time being except when I push the switch the gauge goes completely past full and off the chart . there may be couple gallons , but not full . any idea what that issue may be ?
Thank you |
12-10-2016, 11:05 PM | #5 |
My 87 (tbi) wouldn't run off the passenger tank. Also, the gauge did just as you described. A selector valve, sending unit, and fuel pump later it's fixed. I think the funny readings is the ground. It could be the connection at the frame. My sending units literally rusted in two. I don't know how to advise you other than tear into it and see what you find.
Also, I haven't liked other poly tanks. I'd get a metal one.
12-10-2016, 11:44 PM | #6 |
Thanks . I will tear into it in the morning . This is an 83 so it has a carb with the block mount pump. i need to figure out the ground problem also .
12-11-2016, 01:02 AM | #7 |
Moderator
The carb and diesel ground is a pigtail with ring terminal on the frame end and a 1/4" female disconnect that plugs into a blade on the sender or the tank ring around it.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
12-11-2016, 11:49 AM | #8 |
thank you . should be able to find that
