12-10-2016, 10:57 PM | #1 |
Ford Rack and Pinion to LS Power Steering lines
Does anyone make a kit for stainless/braided power steering lines? I am using a 93 Thunderbird rack and a 07 LS 3 pump. I see some AN fittings on the Borgeson site but not a complete kit. Anyone know of someone making a kit????
12-10-2016, 11:31 PM | #2 |
Re: Ford Rack and Pinion to LS Power Steering lines
Ask rob at nolimit he uses the same rack on some of his kits he might know.
12-11-2016, 07:01 PM | #3 |
I bought a kit here http://www.purechoicemotorsports.com...rod/prd196.htm
It might work for you, but the 45 degree fittings hit the crossmember on my 51. So buying pieces instead of a kit would have been better. |
12-15-2016, 12:34 AM | #4 |
Hey Mallory69, How about posting up how you accomplished this? What tie rod ends, adjusting sleeves, and any brackets you built?
12-15-2016, 04:05 AM | #5 |
http://www.nolimitengineering.com/pr...tegory=6157532 it uses a thunderbird rack maybe thats what he has.
12-15-2016, 06:52 AM | #6 |
Goats86. You can check out some pics on my build thread http://67-72chevytrucks.com/vboard/s...errerid=155940
I set up a jig off the original lower ball joint and just built my suspension off of that reference point. Tie rod ends came from Speedway and I made the tie rod ends. I recently bought a set of billet tie rod ends from Alston chassis. |
12-15-2016, 06:54 AM | #7 |
Thanks Andrew I am probably going with the kit jweb mentioned in his post above.
