12-11-2016, 06:20 PM | #1 |
Transfer case question
Just found out I've got a cracked tail housing on my transfer case. Thought it was where it bolted up, but not that lucky. My truck is a 84 K10 and according to the tag, a 208. A friend says he has one but it's a 241C. Can anyone tell me what will interchange? He said alot of the Dodge transfer cases will interchange. Any help on this?
12-11-2016, 06:56 PM | #2 |
Re: Transfer case question
The 241C succeeded the 208 but was available in driver and passenger drop configuration. As far as tailhousing goes I think you're limited to one from a GM 208 only. The D*dge 208 has a different tailhousing than GM ones use.
Roughly on a 208 there is the rear case half with a rear tailhousing that accepts a slip yoke. On a 241 there is the rear case half, then a short section of housing where the tone ring or gear and sensor/pickup are for the speed and then the actual tailhousing that receives the slip yoke...incidentally this is why slip yoke eliminator kits exist for 241s and not 208s. The D*dge 208 has the rear case half and then a mid length tail with a bolt on yoke. Wouldn't be a bolt-in affair, would require different driveshafts/etc. (side note, I censor F*rd & D*dge because I find them vulgar )
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
12-11-2016, 08:26 PM | #3 |
Worked at ford dealerships for 18 yrs. You don't have to tell me about fords. Looks like I'm in search of a tail housing, thanks for info.
