Old 10-12-2003, 03:09 PM   #1
ocbaud
Garage Queen Material
what can i trash?
since the engine is out of my truck now, i need to get rid of all the junk i dont need so that it will look cleaner under the hood
i know i can pull the cruise control since it didnt work to begin with and i wont ever use it, i will also pull out the electronic spark control crap. what else can i rip out?
ocbaud is offline   Reply With Quote
Old 10-12-2003, 03:17 PM   #2
gldevall
gldevall's Avatar
A/C
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 10-12-2003, 05:32 PM   #3
TIMSPEED
TIMSPEED's Avatar
ALLL the smog crap!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 10-12-2003, 06:29 PM   #4
1FaastC10
1FaastC10's Avatar
Originally posted by TIMSPEED
ALLL the smog crap!
remove all the smog crap, and wire up your TCC lockup like Mike's website shows. that's what i did. if you come up with a creative way to cover the ESC hole, let us know.
1FaastC10 is offline   Reply With Quote
Old 10-13-2003, 02:47 AM   #5
low 84
low 84's Avatar
i removed EVERYTHING. i have 3 vacuum lines now, 1 for the distributor, 1 for the brake booster and 1 for the heater vent opener. i have removed all of the a/c stuff except for the junk on the fire wall which is being removed as soon as i get time to but the non a/c blower box on. as far as engine related wiring i removed everything but, the hot wire to distributor, the tach lead to the distributor, the oil pressure sending unit wire, and i got a 1 wire alternator and the single wire is run through the "air gap" part of my intake so you can't even see it. removed all the emmision equip liek egr, all the charcole/evap stuff, and anything else. i pretty much have an engine simpler than one that would have come out in the 60's
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-13-2003, 07:39 AM   #6
TIMSPEED
TIMSPEED's Avatar
Originally posted by low 84
i have 3 vacuum lines now, 1 for the distributor, 1 for the brake booster and 1 for the heater vent opener. as far as engine related wiring i removed everything but, the hot wire to distributor, the tach lead to the distributor, the oil pressure sending unit wire, and i got a 1 wire alternator, removed all the emmision equip liek egr, all the charcole/evap stuff, and anything else.
Nyah nyah! I got only one! (Vacuum Advance) My heater door is mechanical and I don't have power brakes. But, I have the hose running to my air filter housing, and the PCV Valve tube, as well as the Charcoal Canister tube...but I have a BUNCH of wires on my firewall, and I dunno if I should/need to keep them all. Since I don't have a damn thing electronic under my hood except the Alternator, Starter, Distributor, and Electric Choke.
See Them Here
Old 10-13-2003, 10:16 AM   #7
78SilveradoSWB
78SilveradoSWB's Avatar
Arrow
ALLL the smog crap!
Isn't California pretty stringent on smog equipment? Or is Gov. Elect Swartzenegger going to loosen the "terminator" grip of the smog laws?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 10-13-2003, 10:32 AM   #8
TIMSPEED
TIMSPEED's Avatar
They are...but once your car reaches 30 years old, it's exempt
See Them Here
Old 10-13-2003, 01:33 PM   #9
ocbaud
2003-1975=30???
Old 10-13-2003, 01:41 PM   #10
crackajacka
Stylin
crackajacka's Avatar
lol that would be bad if u went in for an emissions test anytime in the next 2 years
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-13-2003, 02:10 PM   #11
Izzy
Trucker.
Izzy's Avatar
Originally posted by ocbaud
2003-1975=30???
LOL Woops that addition is a little off.
Izzy is offline   Reply With Quote
Old 10-13-2003, 02:28 PM   #12
kevhill85
91 SWB 383
kevhill85's Avatar
i took everything out under the hood
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 10-13-2003, 02:28 PM   #13
kevhill85
91 SWB 383
kevhill85's Avatar
Old 10-13-2003, 02:28 PM   #14
kevhill85
91 SWB 383
kevhill85's Avatar
Old 10-13-2003, 03:02 PM   #15
gldevall
gldevall's Avatar
Hey Kev, did you take everything out under the hood? LOL
Old 10-13-2003, 03:15 PM   #16
Izzy
Trucker.
Izzy's Avatar
LOL, I'm not so sure he did. :p
Old 10-13-2003, 03:33 PM   #17
kevhill85
91 SWB 383
kevhill85's Avatar
this dam cpu is junk .
Old 10-13-2003, 09:57 PM   #18
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Does your emissions label show it as having the "YDR emissions hose routing?" My emissions sticker is the one below.
If it does, and any of it is still in working order I'm willing to pay shipping for the AIR pump and brackets, the smog lines that go to the manifolds and the hoses that cross over the intake, and the thing that goes on the right manifold to make it warm up faster. San Antonio has been warned that we will be having visual and tailpipe inspections on all that stuff soon, but the state won't say when. Those are the items my '86 305 is missing.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-13-2003, 11:06 PM   #19
ocbaud
that is what sticker i have, but sorry, most of that smog stuff has already been taken off long ago and gotten rid of
Old 10-14-2003, 12:32 AM   #20
Slonaker
Slonaker's Avatar
That's the problem around here, too. Those parts are long gone on most trucks. I'm trying to beat the rush that will happen when they start checking. We aren't exempt here until the truck is 25 years old, so I have a ways to go.
Of course I'd be pretty happy if my truck just ran right now...
Slonker
Stock '01 Silverado
Old 10-14-2003, 01:47 AM   #21
TIMSPEED
TIMSPEED's Avatar
California is stupid, they call it 30 years, PLUS the current model year, so I guess you could say it's really 29 years..and my truck isn't exempt YET..as of 1/1/04 it will be though
See Them Here
Old 10-14-2003, 12:46 PM   #22
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I took out all the vacuum lines except for the PCV valve, the HEI advance, the brake booster, the transmission line, and heater line. All the emissions are gone.
BTW: Oklahoma doesn't have emissions testing.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-14-2003, 03:03 PM   #23
crackajacka
Stylin
haha i was wondering about that.hopefully if they ever start having emmision tests my truck will be emmission's exempt
Old 10-14-2003, 05:21 PM   #24
1985K10
1985K10's Avatar
I Have A/C, never use it so I took the belt off. Cranks are cool, wish I had a P/W on the passenger side though!
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 10-14-2003, 08:19 PM   #25
RiverCityChevy
You want it when???
RiverCityChevy's Avatar
Location: I live in memphis,tenn. been here for almost 30 years.
Thumbs up
Heck take out the inner fenders,scrape the firewall clean, make it nekid, j/k use a big hammer...lol
RiverCityChevy
The more Hondas I see the more I love my Chevy Truck.
If you're not out front the view never changes.
RiverCityChevy is offline   Reply With Quote
