71 Vin # help / short box?
Newbie- Trying to find out if this 71/c10 is a short box?
Vin# CS 141 A 632475 4x2 1/2 Ton Straight Six Atlanta The frame seems to be all original until the very end of the frame. No bumper and frame is cut - told me its from taking off a trailer hitch? |
![]() Join Date: Oct 2009
Re: 71 Vin # help / short box?
decode is correct, but VIN won't tell you the wheelbase. If the truck has a SPID, there are two clues:
1) WB of 115 in upper right 2) Model Number: CS10734 = 115 swb (CS10934 = 127 lwb) If no SPID, then a build sheet (under seat would help, IF it's still there) - but can't get out unless rebuilding the seat and ripping it all apart - unless you're lucky enough to have it between the seat springs and cushion face down. Other than that - it comes down to an educated guess by the person onsite inspecting the truck. lwb's are not normally shortened to swb's at the rear behind the axle (without looking a little goofy) - it's normally done just behind the cab/bed junction. That would be the place to look for welds, fish plates, etc. |
Thank you for the quick response - Yes, the frame looks clean and original except the rear. I'm thinking someone wanted to do a rear roll pan and just hacked it up.
An original frame should be stamped with a partial VIN into the top flange by the steering box. In your case it should be 1A632475
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
SS Tim - yes, its printed and matched but how to I ensure its a true short box?
I don't see anything behind the cab or elsewhere on the frame other then the back being hacked that making me second guess. Thanks again |
I have VIN# CS 141A632475
C = 2W S = 1-6 1 = 1/2 TON 4 = ? 1 = ? A = Atlanta 6 = 3 = 2 = 4 = 7 = 5 = Just trying to fill in the blanks... Thanks for you support! |
#7 | |
The Older Generation
8" has to be cut off of the rear frame rails when shortening a long bed frame also..... LockDoc
#8 | |
http://67-72chevytrucks.com/Chevyear.html But like the other guys said, you need the SPID from your glovebox to find out if it was originally a lwb or swb.
_____________________________________________ 1972 C10 - SWB /383 stroker/Th400/3.73/vintage air |
