12-13-2016, 04:35 PM | #1 |
4x4 frame id
Trying to id frame number on top of pass side rail is only one I can find. C7F189923. Any help is appreciated .
12-13-2016, 05:19 PM | #2 |
Re: 4x4 frame id
"C" Is for 2wd. "K" is for a factory 4x4.
12-13-2016, 06:48 PM | #3 |
I think c is Chevy & f is flint plant but not sure if 7 is 67 or 77.
Posted via Mobile Device |
12-13-2016, 07:22 PM | #4 |
All about them K’s
Re: 4x4 frame id
The partial vin if there should be stamped on top of the drivers frame rail just behind the steering box. Correct me if I'm wrong but, mines a partial vin. only the last 6 or 8 numbers of the vin so you won't see anything that is relevant to 2wdvs4wd unless your vin matches the cab vin, at which point you'll know what the truck was originally.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-13-2016, 10:36 PM | #5 |
Thanks for the reply. I looked in front of gear box, I will look again. Thanks
12-14-2016, 01:01 AM | #6 |
All about them K’s
Re: 4x4 frame id
Do you know what year frame you've got? Early GMCs are not as likely to have the vin stamped up by the steering box. Does it have the driver front spring stops or a disk brake front axle?
12-14-2016, 09:36 AM | #7 |
Re: 4x4 frame id
no i dont know the year. that is what im trying to find out. it is a rolling frame that im thinking of buying. owner thinks its a 70-72. i think its 73-80.
12-14-2016, 10:14 AM | #8 |
All about them K’s
Re: 4x4 frame id
If you can post a pic we can identify it pretty easily on here.
12-14-2016, 10:20 AM | #9 |
Re: 4x4 frame id
i dont have a pic . but i think i found it is a 77. it has a th350 tran & np203 case. 67-72 didnt offer 203 t-case that i could find. thanks for your help.
12-14-2016, 11:27 AM | #10 |
Re: 4x4 frame id
Tash4, Your frame is a 1977.
C7F189923 C, if your frame was a 1967 this C would NOT be here. C is for Chevrolet. Also 67s were stamped on the driver side rail only. 73-80 could be driver or passenger side depending on year or assembly plant. 7 = 1977, if it was a 1987 it would have a H here F = Flint assembly plant 189923 = Unique ID, Started at 100001
CHEVY/GMC VIN DECODERS |
12-15-2016, 09:41 AM | #11 |
Re: 4x4 frame id
Thanks bruceman , that confirms what i have found.
12-15-2016, 08:24 PM | #12 |
SWB 4x4 Collector
Re: 4x4 frame id
Also an easy way to tell is that 67-72 shocks mount towards the front of the rear axle. 73+ are stagger mounted.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
