Old 12-13-2016, 05:07 PM   #1
88k5jimmy
1964 rear drum backing plates interchangeability
Long story short, I need the backing plates and all non reproduced parts for a 1964 12 bolt. Are there newer years that interchange with the 1964 that might have better parts availability? I read that maybe 10 bolts up to 1987 would work as long as they had 2" drums. If that's the case will all the other brake parts connect such as e-brake cables from the 1964 to the newer backing plates and internal components? I'm assuming if I were to use the backing plates and non reproduced parts from a newer 10 bolt I would still be able to use the 1964 internal brake components and 6 lug drums as long as everything utilized 2" drums/shoes?
88k5jimmy is offline   Reply With Quote
Old 12-14-2016, 01:30 AM   #2
Captainfab
60-66 Nut
Re: 1964 rear drum backing plates interchangeability
All truck 12 bolts from '64-'82 and truck 10 bolts from '79-'87 will have backing plates and internal parts that will work on your '64 housing. You can stay with the 2" wide shoes and drums or upgrade to the 2-3/4" wide shoes and drums. For the 2-3/4" wide shoes you must have the correct backing plates.
Old 12-14-2016, 12:30 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
X2 to what Captain posted...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-20-2017, 01:51 PM   #4
88k5jimmy
Thanks Captainfab. Are the backing plates themselves (between the years and/or 12 and 10 bolt axles) the same but the hardware, drums, etc different based on which width you go to?
Old 04-20-2017, 11:28 PM   #5
Captainfab
60-66 Nut
The backing plates and drums are different for the 2" wide shoes than those for the 2-3/4" wide shoes. Either will bolt to a '64-'87 10 or 12 bolt truck differential.
Old 04-20-2017, 11:48 PM   #6
88k5jimmy
Thanks. Is there a way to visually tell the difference in backing plates, or a photo comparison you may have in your files?
Old 04-21-2017, 12:02 AM   #7
Captainfab
60-66 Nut
Sorry I don't have any pics of both backing plates on this computer. I would have to take a couple pics and post them tomorrow.
Old 04-21-2017, 12:22 AM   #8
88k5jimmy
That would be great but I don't want you to have to go out of your way if it's not easy.
Old 04-21-2017, 12:23 AM   #9
shortstep60
I have a set of backing plates for the two inch wide off of a 1965 $25.00 plus shipping thanks.
shortstep60 is offline   Reply With Quote
Old 04-21-2017, 10:03 AM   #10
88k5jimmy
Do you have any pics?
Old 04-21-2017, 11:54 PM   #11
Captainfab
60-66 Nut
Sorry didn't have time today.
Old 04-22-2017, 12:02 AM   #12
padresag
the backing plate for the 2 3/4" should have a deeper recess where it goes back over the axle flange I would imagine
ron
padresag is offline   Reply With Quote
Old 04-22-2017, 08:42 AM   #13
88k5jimmy
That's ok. Just if you get time I would appreciate it.
Old 04-22-2017, 12:43 PM   #14
vince1
The 2" on a 66 differential. I hope the picture attaches.
vince1 is offline   Reply With Quote
Old 04-22-2017, 11:28 PM   #15
Captainfab
60-66 Nut
I found some time to take pics today. The first two are of a backing plate for the 2.750" wide shoes. Notice the deeper recess where it is bolted to the axle tube flange.
