Rear cab area
Hey all,
I wasn't exactly sure how to subject this post because I don't see too many posts on forums talking about the rear cab area. I have a '53 five window and I've recently ripped out the original seat and frame and I'm in the process of overhauling the rest of my cab. The area behind the seat needs some love, so I've cleaned it up and installed raammat, but I'd like to build a "wall" that looks clean and hides the raammat and blends with the new interior design. I have a fabric I've selected, but I'm looking for ideas about what material to use to as the backing. Wood, metal, heavy duty cardboard? Any advice is very much appreciated. Thanks! Posted via Mobile Device |
Re: Rear cab area
I'd imagine that the same fiber material that upholstery shops use to make new door panels and back other panels is what you want.
Something similar to this http://www.perfectfit.com/15347/1545...anelboard.html Another source https://www.miamicorp.com/products/S...COWLBOARD.aspx I'd think that there is an Upholstery supply house in the Orlando area that carries what you need though. Here This looks like they might have what you need. http://www.bry-tech.com/
![]() Join Date: Jan 2016
Re: Rear cab area
I agree with Mr48,my gut came to my house and had it done in a couple hours
#4 | |
![]() Join Date: Mar 2007
Re: Rear cab area
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Re: Rear cab area
This is my TF but idea will work for AD. Made templates out of 1/8 masonite frame out of plywood. 1/4 plywood with cleats is covered with light foam and commercial grade chair fabric. After I bought my speakers I added the pods; wood frame, heavy cardboard, tee shirt fabric with fiberglass to shape, then foam and fabric. Same fabric was used on headliner and door panel inserts. I used stick on bubble insulation on the cab back and corners before final install.
Next step will be to add enclosed storage at the bottom.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 12-14-2016 at 02:02 PM. |
Thanks for all the replies and the great information. Like like there are several ways to go about doing it. I'll get to work and post some pics when it's done! Thanks again!
