Old 12-14-2016, 10:14 AM   #1
SuperCtruck
SuperCtruck's Avatar
Transmission cooling lines? Help
I have a turbo 350 mated to a 350 motor I'm getting ready to drop in my 64 c10. I'm having trouble finding straight pieces that are long enough Here at my local parts supplier in town.
The fittings for supply and return lines screw into along the bottom of my radiator. Any info or suggestions are greatly appreciated??!!
1949 Chevrolet 5 window
1970 C10 CST swb, fleet side
1964 C10 swb, bbw
1968 Camaro coupe
1968 camaro convertible (cream puff)
1972 K10 swb 4wd SuperCheyenne
SuperCtruck is offline   Reply With Quote
Old 12-14-2016, 10:43 AM   #2
gabbin
gabbin's Avatar
Re: Transmission cooling lines? Help
Have you checked the 70's to see if those are what you need?
gabbin is offline   Reply With Quote
Old 12-14-2016, 10:55 AM   #3
SuperCtruck
I've looked at a few different parts vendors catalogs and I'm seeing the 70's lines screw in along the passenger side of the radiator.
1964 C10 swb, bbw
1968 Camaro coupe
Old 12-14-2016, 01:15 PM   #4
jtrichard
Call Inline Tube they should be-able to make lines for your combo ....(586) 532-1338 Tech Support Inline Tube
jtrichard is offline   Reply With Quote
Old 12-14-2016, 03:14 PM   #5
Lokin4AReason
Lokin4AReason's Avatar
good to know on reference(s) number(s) on specfic part(s) =)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-14-2016, 06:46 PM   #6
urmyboyblue
Straight pieces? Of hard line? Use large brake line- you can buy them from any auto store in various lengths and bend to fit. I think that they use inverted flares just like brake lines. It is what I have used in the past.
urmyboyblue is offline   Reply With Quote
Old 12-15-2016, 10:14 AM   #7
SuperCtruck
Considering going this route?! I hate bending metal line while measuring on my back
1964 C10 swb, bbw
1968 Camaro coupe
Old 12-15-2016, 04:11 PM   #8
Gunnin4ya
I used the exact set up SuperC is showing and I'm very happy with it. I hid it in the frame really easy.
Gunnin4ya is offline   Reply With Quote
Old 12-16-2016, 09:16 AM   #9
bj383ss
bj383ss's Avatar
I also used the brake lines for my lines for a 700R4. But I did use rubber hose at the end where I hooked it up to the trans cooler.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 12-16-2016, 09:29 AM   #10
Mathew21
Mathew21's Avatar
Bret
That's what I did on my 4l60E.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-16-2016, 10:38 AM   #11
LT1 Burb
LT1 Burb's Avatar
I used inline tube for my trans lines but they were power glide ones, don't know how close the 350 are to them.
LT1 Burb is offline   Reply With Quote
Old 12-16-2016, 01:03 PM   #12
richards72chevy
richards72chevy's Avatar
I modified the cooler lines from my 83 Chevy parts truck to work on my 66 when I put the turbo 350 transmission in it.
richards72chevy is offline   Reply With Quote
Old 12-16-2016, 02:04 PM   #13
SuperCtruck
Ok that's reussuring man, thanks
1964 C10 swb, bbw
1968 Camaro coupe
