Old 12-14-2016, 01:20 PM   #1
1985 single cab 1 ton dually manual trans. Is transfer case a 205?
Up here in Hailey, ID. and its too dang cold and too much snow on the ground to crawl underneath and look. My guess is a 205. Trying to do some homework, thanks!
Old 12-14-2016, 03:14 PM   #2
jeffahart
jeffahart's Avatar
Re: 1985 single cab 1 ton dually manual trans. Is transfer case a 205?
Could be, but more likely an NP208.
Scratch that.. civilian 1 ton likely NP205, military NP208. That's what I'm thinking.
White K20
jeffahart is offline   Reply With Quote
Old 12-14-2016, 04:06 PM   #3
b454rat
All 1 tons in the 80s had the 205. Military is different, but the duallys did get it too. If it doesn't have a 205 it was swapped in.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-14-2016, 04:31 PM   #4
Thanks!
Old 12-14-2016, 09:13 PM   #5
andrewmp6
It should be a np205,You can take a picture of the shifter in the cab,The shifter is different between a np208 and np205.
andrewmp6 is offline   Reply With Quote
Old 12-15-2016, 02:09 AM   #6
kwmech
No need, as stated all 1 tons got the 205
Old 12-15-2016, 09:18 AM   #7
obijuan
They all came with them. however, I have castrated several k30s and resold as k20s. What they had 30 years ago may not be what they have now.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 12-15-2016, 10:56 AM   #8
That's guys, I have a SM465 with a Gear Vendors overdrive unit in the truck, the GV keeps blowing the fuse, I think the solenoid is bad.
Old 12-15-2016, 12:15 PM   #9
Matt Man
Matt Man's Avatar
Why did the military have 208's? Is it because of the lower ratio?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-15-2016, 12:58 PM   #10
b454rat
Potentially, although you can shift 205s into 4wd on the fly, I think 208s are lil easier. But don't know the "real" reason. Why military intelligence is the biggest oxy moron....
Old 12-16-2016, 03:31 AM   #11
andrewmp6
The military blazer used the np208 so maybe they wanted the pickups the same so they will interchange and have parts easier.
Old 12-16-2016, 11:47 AM   #12
jeffahart
jeffahart's Avatar
It was probably GMs choice. The military usually starts with a concept to fill a need. The vendor produces a vehicle that fits the criteria. Then the Army takes your vehicle, weapon or whatever, to the proving grounds and they thrash it. If it lives they order a whole bunch and you get rich. So I guess the 208 survived the proving grounds. But of course we all know the CUCVs did not stand the test of time for Military abuse.
White K20
Old 12-16-2016, 04:55 PM   #13
95 S_Trucker
95 S_Trucker's Avatar
Its easy, cast iron case=205, Aluminum case=208
95 S_Trucker is offline   Reply With Quote
Old 12-17-2016, 04:03 AM   #14
andrewmp6
95 s trucker you forgot gear driven 205 and chain on the 208.
Old 12-17-2016, 07:07 AM   #15
95 S_Trucker
He's looking for a quick id without freezing. We can go on and on about the differences between the 2 cases.
Old 12-17-2016, 10:47 PM   #16
andrewmp6
The shifter in the cab on a 205 is straight up the 208 leans foward some.
Old 12-19-2016, 12:28 PM   #17
jeffahart
jeffahart's Avatar
Yes, now we need to turn the conversation to getting him some foul weather gear, so he can get under the truck, we want pics/info. And on the GV too lets not forget.
I just got a Christmas idea for 57NapCo! He needs one of these. Good for cold plus, it's orange so wife won't run him over in the driveway!
Merry Christmas 57NapCo!
White K20
Old 12-21-2016, 02:43 AM   #18
Fly and drive number 25 +/-
Just got home, 1900 miles...no issues. I spun that ol big Block pretty tight going 70 mph for a bit. In the interest of getting home, I pulled it back to 60-65, 8-10 mpg
1985 GMC 1 ton single cab dually 4X4, factory air, stock big block, sm465, 4:11's, GV overdrive unit (not working for trip), no rust, 122,000 miles... seems possible. Bumps and bruises ah plenty.
Red River NM ah couple nites ago.
Old 12-21-2016, 04:05 PM   #19
jeffahart
jeffahart's Avatar
I am interested in the nuances of the GV, with the 465/205 setup, when you get it running. I am thinking about maybe getting one. I only know of people that have them. But I don't personally know anyone that runs one. I kind of want one, but without getting in a vehicle with one, not sure about the bucks just yet.
White K20
Old 12-21-2016, 10:36 PM   #20
focusedontheprize
focusedontheprize's Avatar
It is a great looking truck and it is in for a summer-hot-weather wake up call in Texas.
focusedontheprize is offline   Reply With Quote
Old 12-22-2016, 01:47 AM   #21
El Dorado Jim
Smile Re: 1985 single cab 1 ton dually manual trans. Is transfer case a 205?
Attachment 1601485
Thats funny right there!!!!!
El Dorado Jim is offline   Reply With Quote
Old 12-22-2016, 08:01 PM   #22
Mike C
Mike C's Avatar
That's a GREAT looking dually! I've got an '86 K30 dually with 454/4 speed and a 205. But it's been rode HARD and put up wet as they say. But it was cheap!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-22-2016, 08:44 PM   #23
Originally Posted by Mike C View Post
That's a GREAT looking dually! I've got an '86 K30 dually with 454/4 speed and a 205. But it's been rode HARD and put up wet as they say.~(most of em have been)~ But it was cheap!
I have another, nicer one
Old 12-22-2016, 09:28 PM   #24
72 paul
Gonna keep the gv in it? I'M looking for an adapter for gv to 205.
72 paul is offline   Reply With Quote
Old 12-22-2016, 09:41 PM   #25
Yes, gonna keep it as long as it's not toast, I'll order a solenoid for it and see.
