Old 12-14-2016, 10:50 PM   #1
Buffalocouleekid
Buffalocouleekid's Avatar
4x4 SWB 1970 CST/10 Build
Hello all and welcome. Starting a build thread for my project. It started when I found a 1970 CST/10 LWB on craigslist with factory air for $500 (score!) and on the way home I had big plans. Next I bought a 67 4x4 LWB frame and then also acquired a 4x4 87 to part out. I currently have the 67 frame sandblasted and painted with POR 15. There was quite a bit of rust in the rear cross members and I am currently doing rust repairs on them. I took the axles from the 87 and went through them and replaced all the seals, bearings, and brakes. I also took the rear spring mounts from the 87 (shorter than 67 for swb conversion and old ones were pretty rusted) and the transmission/transfer case. I am currently bouncing between repairing cross members and mounting the rear springs. I built new front spring mounts (I was missing the old ones) for my new front springs. Once I get the rear springs mounted I should be able to mount my axles and torch the frame in half for the SWB conversion. Ill try to add pictures.
1970 C/10 LWB 2wd
1970 CST/10 LWB 2wd (soon to be)SWB 4wd
-Trevor
Buffalocouleekid is offline   Reply With Quote
Old 12-14-2016, 11:12 PM   #2
Buffalocouleekid
Re: 4x4 SWB 1970 CST/10 Build
Attachment 1600130
The 87 I robbed axles, transmission, spring mounts and other little things from. also shows my instagram name on top if you want to see more pics of my stuff haha
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:28 PM   #3
Buffalocouleekid
I cant figure out why some of my pictures are sideways but this was was left of the 87
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:34 PM   #4
Buffalocouleekid
Attachment 1600151
This is one of the cross members while in the middle of repairing it.
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:37 PM   #5
Buffalocouleekid
This is the worst cross member. Rust had built up almost an inch thick and had pushed and bent the frame up. this is the bottom side of the cross member that goes in between the front rear spring mounts.
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:41 PM   #6
Buffalocouleekid
Size:  35.4 KBName:  IMG_3739.JPG
the 87 axles. The rear has all the spring and shock mounts cut off because its not in the same location as a 67. the front bolts right in. excuse the mess in these pictures. I am a messy worker
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:47 PM   #7
Buffalocouleekid
This is what it looks like now, upside down and mounting springs. I am going to just bring my camera out instead of taking all these pictures on my phone to email them to myself and save and yada yada yada
1970 C/10 LWB 2wd
-Trevor
Old 12-14-2016, 11:57 PM   #8
Buffalocouleekid
Size:  75.3 KBName:  IMG_1646.jpg
Don't know why these are sideways so don't hurt your neck checking out these good looking pickups. The copper one is in a million pieces spread out on the farm and the teal one I have since taken down to the frame and clear coated the patina since this pic last year.
1970 C/10 LWB 2wd
-Trevor
Old 01-13-2017, 10:14 PM   #9
Buffalocouleekid
Update: got the frame flipped right side up and got my 87 axles and suspension mounted on. next I will probably work on mounting the steering sector and 700r4 cross member. pictures will come if I can remember.
1970 C/10 LWB 2wd
-Trevor
Old 01-14-2017, 08:58 AM   #10
GR8-68
GR8-68's Avatar
Nice build
When you take your pics with your phone hold your camera sideways with the bottom of your phone to your right, volume buttons facing down and they will post right side up everytime.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-14-2017, 07:27 PM   #11
Buffalocouleekid
I think I got it figured out!
1970 C/10 LWB 2wd
-Trevor
Old 01-17-2017, 10:20 PM   #12
Buffalocouleekid
Sooo I got tired of walking around this long frame so I decided to cut it up
I did the basic step notch with rounded corners, I ordered an inner sleeve from earlier classic enterprise for extra strength. Used the plasma cutter and spent 1/2 the day today measuring. Plan on starting to join everything together tomorrow. It will be nice to have a SWB!
1970 C/10 LWB 2wd
-Trevor
Old 01-30-2017, 05:22 PM   #13
Buffalocouleekid
got the frame welded back together and put a glove in. Now building a mount for my anti roll bar
1970 C/10 LWB 2wd
-Trevor
Old 01-31-2017, 06:00 PM   #14
El Dorado Jim
looking good!!
El Dorado Jim is offline   Reply With Quote
Old 02-05-2017, 05:27 AM   #15
ak47paul
Nice job on the frame. I was in the same boat I had bought a 1971 4x4 frame that needed alot of rust repair, I decided to put my 70 chevy over on a 85 suburban frame instead.
ak47paul is offline   Reply With Quote
Old 02-25-2020, 11:12 PM   #16
Buffalocouleekid
Been a minute since posted last but it’s just been boring bodywork past few years. Rust repair and body filler. Getting paint in the next few days so thing will actually Change how it looks. Got the floor of the cab primed so it looks like there’s progress.
1970 C/10 LWB 2wd
-Trevor
