Bed sills question
I have a 62 cab and bed that I'm installing on a 64 chassis and wondering do I order sills for 62 or 64, or do I need to make my own.
![]() Join Date: Nov 2013
Re: Bed sills question
You need to get them for a 1964
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Order for a 64 but only the rear should matter.
The rear on a 60-62 is 42" and the rear on a 63-66 is 34" wide
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Moderator
![]() Join Date: Dec 2012
If you have a mixed group of used sills, it's easy to move the frame pads. Just drill out the spot welds, and weld them back in the correct location. I did this for a couple on my 65 when I replaced all of them.
Ok thanks guy I'll be ordering some from lmc
I would suggest Mar-K, they make them and Lmc just sells Chinese stuff imo.
Moderator
You're in Cali... lots of good rust free used parts...
Can i use my sills from my fleetside long bed and cut down? I might take a trip to the pamona swap meet to find some parts. Are there any sites that sell quality reproduction parts.
Moderator
Cut down? Cut down what? There are just less sills, they're not different.
The OP never said if bed he is wanting to use is long bed or short OR if step or fleet ...only has said he has long fleet donor? SO it makes it hard to guess just what he is trying to do
Ok sorry all I just bought a 62' shortbed that doesn't have all the sills, but I have a 62' fleetside long bed with all the sills wasn't sure if those would fit. And I'm using a 64' chassis now that has been shortened.
I have sills off a 62 fleetside long bed but seem big for my new 62 stepside shortbed cab should they fit?
#13 |
Fleetside cross sills are longer that a stepsides sills.
