12-15-2016, 09:23 AM | #1 |
Tire Size Recommendations
OK folks so I just received my new Intro's for my 87 C10 and need tire size recommendations. I am using a step side bed (not that i think it matters but just a FYI) and Porterbuilt Stage 3 Coil over set up on the truck.
The rims are a 22x10 in the rear and 20x8.5 in the front |
12-15-2016, 11:49 AM | #2 |
Re: Tire Size Recommendations
22x10
285/40-22 30.9" tall 4.48" sidewall height 1.12" of tire per inch of wheel I would def double check the 10" wide wheel fitting within the step-side well @ the planned ride height. I imagine back-spacing will be critical. Closest match for the front: 20x8.5 245/45-20 28.68" tall 4.34" sidewall height 1.13" of tire per inch of wheel The dilemma will be the front height of that tire interfering w/the OE inner wheel tub. If sticking w/OE inner tubs, a 245/40-20 would be another option: 245/40-20 27.7" tall 3.85" sidewall height same 1.13" of tire per inch of wheel
12-15-2016, 07:53 PM | #3 |
Diggin The SquareLife
Need to knw how much its lowered
12-16-2016, 01:26 AM | #4 | |
