Old 10-12-2003, 08:01 PM   #1
benscool1
benscool1's Avatar
flip kit?
What all does it take to install a flip kit? What exactly does it do? How well does it work? How much does it actually lower the truck? I was thinking about just doing this and holding off the big drop stuff til later when the money is more plentiful, cuz I'm thinkin its gonna run reaal thin when we start workin on the motor more.
Thanks,
- Ben
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 10-12-2003, 11:26 PM   #2
SCOTI
SCOTI's Avatar
Re: flip kit?
A flip kit can be installed w/basic hand tools.... rachets, wrenchs, jack stands, jack, & a buddy to help would be good.
It repositions the rear end housing above the leaf springs instead of below, thus lowering ride height w/o changing spring rate or load capacity.
They work great if you want that much drop.
It lowers the rear of the truck the diameter of the housing tubes + the thickness of the spring pack. Since trucks have different spring packs depending on options, you need to measure yours to know the exact amount of drop. Typically you get 5-6" of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2003, 11:31 PM   #3
benscool1
benscool1's Avatar
Wow, thats gonna be quite a bit lower...What would i need to do upfront then? just cut out a coil or two? I just basically wanna make it sit even.
Oh yeah, and won't it mess up the suspension travel? Its 6 inches closer tot he stop than it normally is...what do you do bout that?
Ben
84 C10 Silverado
14 Silverado Z71
Old 10-13-2003, 09:12 AM   #4
SCOTI
SCOTI's Avatar
With just a flip kit you'll be ok if you remove the factory bumpstops. After I did my flip kit, I added shackles so I'm even lower & it only bottoms out on rough/sudden bumps w/the bumpstops removed. I've got a c-section to install..... just haven't gotten around to it yet. I can't put any weight in the bed w/this current set-up.
For the front, use some drop spindles & trim no more than 1 coil w/a cut-off wheel (start w/a 1/2 coil & see if your level.... trim more if needed). It's always easier to cut more, but you can't add it back.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2003, 10:58 PM   #5
benscool1
benscool1's Avatar
What EXACTLY is a C-section? So you can have more rear suspension travel w/a flip kit? With a C-section would I still need to remove the bumpstops? Can you use a sawzall instead of a cut-off wheel?
Thanks,
- Ben
Ben
84 C10 Silverado
14 Silverado Z71
Old 10-13-2003, 11:39 PM   #6
SCOTI
SCOTI's Avatar
A c-section either bolts or welds on to the frame rails just above the rear end housing. It's name is derived from the fact that it is 'C' shaped notch centered in metal plate. It is actually installed w/the notch directly above the housing so extra clearance is achieved when fully dropped.
Yes, the bump stops will still need to be removed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2003, 12:09 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
This is a C-notch on my 82 Blazer. This notch was built, not bought. Any that you buy won't look this smooth...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
