Old 12-17-2016, 10:49 AM   #1
tjc
tjc's Avatar
scott's weld in ifs need info
The instructions say to mark centerline of old front suspension. and I am starting with a bare frame. Does anybody have a reference point of centerline on their 68 front suspension? Has anybody installed a weld in version? Need info
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 12-26-2016, 11:07 AM   #2
tjc
tjc's Avatar
Re: scott's weld in ifs need info
still looking for help
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 12-26-2016, 12:03 PM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Kinda vague on the question so I'll ask you some. What's a "Scotts weld in?" You say you have a bare frame, how bare? Got some pics? A bare frame can mean no front cross member or axle...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-26-2016, 05:08 PM   #4
tjc
tjc's Avatar
no front cross member or rear axle just a couple mid crossmembers. I want to weld in a IFS from Scotts hot rods. and without the front suspension, I need to draw a line from front spindle to other front splindle. I need to know where it crosses the frame
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 12-26-2016, 09:39 PM   #5
PGSigns
PGSigns's Avatar
I know the frame drawings are in the 60 to 66 FAQ section that show all the locations and measurements. Not sure if they are in the 67 to 72 section. You could post in the regular truck section and ask if any one has a frame sitting around that can get you measurements. Lot more chances someone will see the request. A better title would be "Need frame measurements" and post the year and length of the frame you need measurements off of.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-27-2016, 11:19 AM   #6
SCOTI
SCOTI's Avatar
Going by others measurements might not be the best approach here (where they're pulling measurements from; how they're measuring, etc...).
Besides the frame rails/mid x-members, how much more of a truck do you have? I would drop the cab on the frame & mock the front fenders up to get a visual of where you want things & work from there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-27-2016, 05:30 PM   #7
tjc
tjc's Avatar
found the dimensions I needed from a 67-72 chevy service manual.
Thanks for the feed back
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 12-30-2016, 12:16 AM   #8
low69chevy
low69chevy's Avatar
Post Re: scott's weld in ifs need info
If i would of seen this before i would of helped out i had the same questions when installing mine on my truck if you want look thru my build thread theyre should be piks on theyre of when i installed it im tryin to load some here but its giving me a hard time
low69chevy is offline   Reply With Quote
Old 12-30-2016, 12:25 PM   #9
tjc
tjc's Avatar
hey low69chevy...did you have to spread the frame, to weld in the Scotts cross member?
I am about ready to box in the frame and weld in the motor mounts,
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 12-30-2016, 05:31 PM   #10
Boog
laying low
Boog's Avatar
I'm sure you have a good reason for replacing the well designed GM front suspension but if i were you i would contact Scotts for their reference points since they designed their setup
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-30-2016, 07:34 PM   #11
low69chevy
low69chevy's Avatar
Not that i remember i got all my measurements first and it actually fit pretty well i then tacked it in and had a friend of mine weld it in with tig like i said on my build thread i have a bunch of pik that might help im boxing my frame also
Heres some piks i copied and pasted off my thread it shows when i got the old one off and with the Scotts crossmember on
Old 12-31-2016, 09:58 AM   #12
tjc
tjc's Avatar
is that a Scotts weld in ifs, mine have different ball joints. Is you truck back on the road yet?
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
Old 12-31-2016, 12:38 PM   #13
low69chevy
low69chevy's Avatar
Yes its the scotts weld in and no im still working on it
