Old 12-17-2016, 03:55 PM   #1
rvrfoot
66 steering column
Has anyone rebuilt a steering column? Do you need a bearing puller? Can you just basic tools?
rvrfoot is offline   Reply With Quote
Old 12-17-2016, 08:14 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: 66 steering column
I rebuilt my manual column, including the lower bearing. New lower bearings are available from the vendors. Make sure the inner steering rod has not been severely scored or damaged by a failed lower bearing.
It doesn't require any special tools. Just stay organized.
I have photos of most of the reassembly. Just tell me what you need.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 12-17-2016, 08:19 PM   #3
Lugnutz65
Lugnutz65's Avatar
Lower bearing. Use a paper cone inside the lower bearing to keep the bearings in place until you install the race. Use lots of bearing grease too.
Old 12-17-2016, 08:24 PM   #4
rvrfoot
thanks nice pictures
Old 12-18-2016, 09:21 AM   #5
vince1
Mine was cut quite deep from failure of the lower bearing. If you can find a collapsible 67 shaft it can take the place of the 66 shaft.
Besides a replacement bearing an alternate bushing is also available. As mine is a 4sp I don't know if shift linkage would make any difference in the use of that bushing.
vince1 is offline   Reply With Quote
