Old 12-17-2016, 06:22 PM   #1
cavedog309
New Member
cavedog309's Avatar
12 Bolt 3 Series
In need of Differential Guru ? Have 81 C10 with 6 Cylinder , Turbo 350 and 12 Bolt Truck Differential Changed out to 350/350 but doesn,t matter i guess. Anyway in my research online that has me confused . Evidently I have a 3 Series 12 Bolt Rear. Does this mean I can only run up to a 3.42 Posi Trac rear ? Or can I run a 4:new: Series as Long as I use the 4 Series Carrier ? :ito::ito:
cavedog309 is offline   Reply With Quote
Old 12-17-2016, 09:57 PM   #2
69heavychevy
69heavychevy's Avatar
Re: 12 Bolt 3 Series
you can run 3.73's on a three series carrier. I wouldn't be surprised if someone made 4.10's for a 3 series carrier...but yea, usually 4.10 and lower will require a 4 series carrier
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 12-18-2016, 06:04 AM   #3
cavedog309
New Member
cavedog309's Avatar
69 Heavy Chevy , How can one differentiate a 2 series from a 3 and 4 series ? This unit I have may even be a 2 series now that I have read more into these rear drives. Very Confusing, I always thought a 12 Bolt was a 12 Bolt ???
Old 12-18-2016, 08:38 AM   #4
Desert1957
Desert1957's Avatar
Looks like everything is available.
http://www.jegs.com/p/Richmond-Gear/...44482/10002/-1
Desert
Desert1957 is offline   Reply With Quote
Old 12-18-2016, 02:15 PM   #5
bdiamond
The flange where the gear bolts on is thinner on the 2 series than the 3 or 4. Pinions get smaller the higher number gear you go to. Theres an ID chart online somewhere.
Here you go......
http://67-72chevytrucks.com/vboard/s...d.php?t=347930
bdiamond is offline   Reply With Quote
Old 12-18-2016, 04:14 PM   #6
cavedog309
New Member
cavedog309's Avatar
Thank You for the explanation, Much Appreciated !
Old 12-21-2016, 09:32 AM   #7
Fuelster
Truck 3 series will not work with OEM 3.73 gears. 3.73 is the 4 series carrier.
Member # 286
1975 Trans Am
1986 GMC Wrangler 4X4
1985 Silverado K30 Dually
2016 Skidoo Renegade XRS 800
2016 Yamaha Grizzly 700
Fuelster is offline   Reply With Quote
