'59 door rust
I knew I should have kept working on the top. Decided to grind on LT door, surprise...not really. Not quite sure which direction to go on this. I probably could fab something, but man, pretty forked up...thoughts? Kel
Re: '59 door rust
More pics..
Re: '59 door rust
My 58 is rusted in the same area , i am guessing it has to do with the windows scraper seal (whatever its called) that is supposed to keep the water from running inside the door
I am going to have to patch the bottom of my passenger door , though the skin on mine seems intact (from what i can tell without sanding/grinding) , but the bottom of the door is pretty much toast , thats what happened from it sitting outside for about 15 years , neglected |
Re: '59 door rust
Most of these trucks have rust there unless it has already been repaired. Patch panels are available to repair it.
Re: '59 door rust
I'll be danged, I knew there were patch panels for the outter skin, just saw where inside panel is available as well...Google IS your friend, thx.
Re: '59 door rust
Don't know if that bottom picture is a optical illusion or not, but it looks like that door has had a bottom skin put on it once before. You would have thought if someone had been that deep in the door before it would have some type coating to protect.
I have put new bottoms and outside skins on my doors. All of the news panels fit pretty well. Just make sure you read an article on planishing welds with all of the flat weld area on the outside skins. JT from SC |
Re: '59 door rust
I know that I'm new to this forum, but I just did this repair on my 55 2nd, not hard to do at all! If I can get my pictures to work I'll post up a few. Just measure measure measure!!!!
1969 GMC 1/2 Ton 1955 Chevy 4400 series 1.5 ton truck 1949 Dodge Coronet 1972 GMC Sprint 350 with th400 ![]() Not bad for a 20 year old!!! |
Re: '59 door rust
Here's a few of mine, sorry they're upside down.
![]() No mud work ![]()
Re: '59 door rust
Nice work Materman.
Re: '59 door rust
Thanks!
![]() ![]() Join Date: Nov 2008
Re: '59 door rust
Totally replaced both my door bottoms with repop bottoms from The Car & Truck shop. Took a little fiddling to make it fit right but now it's done and looks great. I'm pleased. I suggest going this route if they're Swiss cheese like mine were after sandblasting.
See below for door interiors and lower outer skins: http://www.truckandcarshop.com/trucks47_59/t47_065.html
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Re: '59 door rust
#13 |
Re: '59 door rust
Looks great.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#14 |
Re: '59 door rust
Thanks!
Makes you feel even better when you get to this stage. All the work really pays off. |
#15 |
Re: '59 door rust
Thanks for the pics fellas, will be big help when this phase gets going, Kel
#16 |
Re: '59 door rust
Parts came today...I guess you guys did the outter skin first, then inner?
#17 |
Re: '59 door rust
Yes, that's what I did. This allows access for holding a dolly while you planish out the welding shrinkage. Even then it's difficult to get the panel flat. I got it the best I could but had to use filler to get it perfect. My intent was to not have filler any more than 1/8" thick but it may be 3/16" in places.
#18 |
Re: '59 door rust
Well, I guess I'm going in the right direction. Really wanted to start welding it up, but decided best to wait till tomorrow so I won't rush.
#19 |
Re: '59 door rust
Check your door hinge connect braces for cracks first.
I had to remove mine and repair. |
#20 |
Re: '59 door rust
#21 |
Re: '59 door rust
Take a good close look at the lower hinge mounts. Mine were cracked around the weld nuts. It is easier to remove/repair those now before welding the skin back on. Somewhere in roger55's build thread, he shows how to repair if needed.
edit: Roger, you're fast. You found and posted those pictures faster than I type. Sorry to be redundant. Last edited by BIGglaSS; 12-28-2016 at 12:02 AM. |
#22 |
Re: '59 door rust
When you go to bend the outter skin edges, do you use the flat panel pliers, channels locks or hammer them over. I don't have the panel pliers, think I saw them at HF for about $10, others around $40?
#23 |
Re: '59 door rust
I hammer and dollied mine with good success.
#24 |
Re: '59 door rust
There is a special hammer for doing it.
I bought one of those hammer and dolly kits from HF and it had one in there. It was the first time I had done this and I thought that hammer worked very well. |
