Old 12-18-2016, 12:28 PM   #1
paul blair
69 k/10 front leaf springs
My k/10 front leaf springs have a negative arch and the ride is wimpy! They are 2 leaf. Thinking of installing k/20 3 leaf. Wondering if 3 leaf would be a good choice? The Truck has a STAHL utility, overload springs and air bags, so the rear suspension seams ok. Any thoughts? Also I always wondered why my 69 k/10 has c/10 emblems! GOD BLESS YOU ALL-HAPPY TRAILS-HAPPY HOLIDAYS
paul blair is offline   Reply With Quote
Old 12-18-2016, 02:00 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: 69 k/10 front leaf springs
All stock springs will have a negative arch. 3 leaf will swap in just fine.
Tyler
57taskforce is online now   Reply With Quote
Old 12-18-2016, 02:33 PM   #3
B. W.
B. W.'s Avatar
X2 with 57taskforce -but it's likely your springs are old & tired. Does the front end sit lower than the rear? one P/N for K20 front springs (3 leaf) is 22-384 from General Spring, made in Canada, 1,110# rating. There are other weight options.
B. W. is offline   Reply With Quote
Old 12-18-2016, 03:44 PM   #4
72 tigger
72 tigger's Avatar
All K10/20's have C10/20 emblems- no such thing as K10 or K20 emblems. Blazers have K5 emblems- Merry Christmas!
72 tigger is offline   Reply With Quote
Old 12-18-2016, 03:50 PM   #5
CUSTOM/10
CUSTOM/10's Avatar
I agree with everything said above.
I had a K10 SWB with 3 leaf springs that I used for plowing, worked good. So if you don't have a plow on your truck it may sit a little bit higher & a bit stiffer but no too much.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-18-2016, 04:35 PM   #6
57taskforce
All about them K’s
I understand what your trying to say and I'll clarify by saying lower trim level trucks had the c emblems. I don't think Custom deluxe had them and I know Cheyenne and super did not have the c emblems.
I've always thought that the c was a reference to the custom trim level as opposed to being two wheel drive but I could be wrong.
Tyler
Old 12-18-2016, 05:13 PM   #7
72 tigger
72 tigger's Avatar
You're correct- if they did use the "K" designation would that have made the upper level trucks Kheyennes?
Old 12-18-2016, 05:37 PM   #8
paul blair
Thanks 57TF,B.W.72Tiger and CUSTOM10 !!!! I think I will go with the 3 leaf, the STALL utility bed is heavier than stock and since new, the truck seemed weak in the front. Thanks again for the information!
