Old 12-18-2016, 11:26 PM   #1
vht
Adapter 700 to a 350
If anyone has or knows where I can get just the adapter, spacer, to go from a 700R to a 350 turbo, please message me. Found the complete TCI kit, but if I could get the spacer separate it'd be great, thanks.
vht is offline   Reply With Quote
Old 12-19-2016, 10:03 AM   #2
D13
D13's Avatar
Re: Adapter 700 to a 350
2wd 4wd?
2wd, get a TH350 drive shaft, we made millions of 2wd with TH350, vacuum T and hose, and a kickdown cable and carb fitting.
4wd, if you don't want to move the Tcase and play with driveshaft lengths, you need an adapter, and depending, to change the 350's output shaft to get the correct length. At least I know thats how we did it on the S10 blazer.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 12-19-2016, 01:49 PM   #3
vht
4WD, I know, that's the adapter I'm referring too. TCI has a kit, PT # 329900, but I was hoping to just find the spacer and cut my rear shaft. May have to bite the bullet and buy the kit. Thanks for the response.
Old 12-19-2016, 05:55 PM   #4
hatzie
Moderator
hatzie's Avatar
What transfer case are you trying to mount?
The common TH350 is setup for the NP205 or NP203. The TH700R4 to NP208 NP241 adapter will bolt up to the TH350 but the output shaft will not reach the transfer case input splines.
There was a rare TH350 version in the early 1980's that has a longer output shaft for the NP208. The TCI kit contains this longer output shaft and a few other parts needed for the swap.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-19-2016, 10:15 PM   #5
vht
I thought from what everyone said that the rear sfaft was to long, and you could cut it off. I'll more than likely go with the TCI kit, I can get it through Summit Pro Shop for $180. Thanks for the info.
Old 12-19-2016, 11:12 PM   #6
hatzie
Moderator
hatzie's Avatar
It depends on the TH350 build year.
If it's attached to the NP203 it has a short shaft. The NP205 was used through the 80's so it's a guess. Measure it.
Old 12-20-2016, 08:49 AM   #7
vht
It's a short tail 350 out of a car. If memory serves me right, we cut 1 1/2 off the tails haft and used them in 4x4. We used the 9 in in 2WD.
Old 12-20-2016, 08:52 AM   #8
b454rat
I have a kit to adapt 700 to 350, never used it. I can't think of the kit, was a common one in the 90s and early 2000s I believe. I can get pics any part number if interested.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-20-2016, 06:19 PM   #9
vht
b454rat, PM sent, and thanks.
