Old 10-12-2003, 10:31 PM   #1
orange72350
orange72350's Avatar
Engine+Tranny Install
I pulled my tranny and engine outta my 72 gmc the other day. Will i be able to put the tranny/engine back into te truck together without pulling the whole front clip/grill? if not, whats involved in taking the grill out? btw, its a 72 gmc with a 350/350 combo
thanx
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 10-12-2003, 10:33 PM   #2
racedvl
racedvl's Avatar
I have done it, but I have mental issues. . . .
racedvl is offline   Reply With Quote
Old 10-12-2003, 11:23 PM   #3
orange72350
Any ideas what this combo weighs?
Old 10-12-2003, 11:24 PM   #4
crazy longhorn
Fabricate till you "puke"
LOL! I have those issues also when it gets real bad , its like this You can install the eng/ trans together, but a tilt/leveler is a good investment. the parts need to go a long way up to get over the rad support. If you opt to remove nose pcs, I would pull the complete front clip. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-12-2003, 11:31 PM   #5
crazy longhorn
If your hoist will handle 1000 lbs with the boom all the way out, you will be fine.....you will be a tad under that(about 550 on the eng, & 200-250 on the trans & converter.
Old 10-12-2003, 11:31 PM   #6
crazy longhorn
Didnt need that 2 times:p
Old 10-12-2003, 11:40 PM   #7
orange72350
whats involved in pulling the whole front clip? if its rough, then ill just stuff the engine in, then the tranny from underneath. thanx
dale
Old 10-12-2003, 11:53 PM   #8
crazy longhorn
Open the doors, & unbolt the cowl panel, should be 4 -5/16 bolts, ,a hand full of screws & the wipers. I am guessing you already have the hood off. The fenders have 2 bolts ea side hidden under the cowl, 1 ea side on the bottom, 1 ea side where the inner fenders bolt the the cab, the rad support mounts, & the wiring harness......I think that covers it. if you arent dealing with rusty fasteners, its not too bad a job.......crazyL
Old 10-13-2003, 07:30 AM   #9
rage'nrat638
rage'nrat638's Avatar
i just stuffed my engine in with out pulling the hood
rage'nrat638 is offline   Reply With Quote
