Old 12-20-2016, 09:15 AM   #1
Doug66
66 Volt Gauge Wiring
I'm stumped. My 66 volt gauge wiring is two hot leads coming from a ballast resistor mounting on the L. inner fender. 12.3 volts measured at both terminals of BR. Wiring diag. attached. Is this install factory as I can't find a diag. online to confirm? Gauge does not move with or without power from batt or engine running. Wiring to gauge is not factory.
Thank you as wiring is not my forte.
Doug
Doug66 is offline   Reply With Quote
Old 12-20-2016, 09:54 AM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: 66 Volt Gauge Wiring
That is not factory. It would serve no purpose in any vehicle so it's no wonder you never see it move. Also, the gauge in the dash is an ammeter, not a voltmeter. There are factory wiring diagrams posted in this forum. Search there to see how to return it to stock and get it working again.
VictoriaHardware is offline   Reply With Quote
Old 12-20-2016, 10:39 AM   #3
Doug66
Thank you very much and I'm not surprised it a bungle job considering the prior electrical finds and corrections. They had a relay wired to the HEI power lead and would not start at times, etc, etc... I don't like amp gauges of course and I'll see if it can be converted to volts and leave the face alone.
Merry Christmas to you and all.
Doug
Old 12-20-2016, 10:50 AM   #4
Doug66
Called Ron Williamson at Williamson's Inst. and he converts gauge from amps to volts using original face. Great company by the way.
Old 12-20-2016, 11:29 AM   #5
PGSigns
PGSigns's Avatar
In that drawing the gauge is hot on both sides. Never work like that. I assume it is hooked to a aftermarket volt gauge.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-20-2016, 01:48 PM   #6
Doug66
Hi Jimmy,
Yes, it is hot on both sides and may be fried inside. I just got done taking the ballast resistor out of the truck and the wiring. I'll wait until after the Holidays to send the gauge out to have it converted to volts with the same face plate by Williamson. I could write a book on the electrical stuff I've fixed on this great truck (it's great now I should say).
Doug
Old 12-20-2016, 02:59 PM   #7
PGSigns
PGSigns's Avatar
So it was hooked to the amp gauge not a volt meter.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-20-2016, 03:38 PM   #8
earl84
That's awesome! I've tried to install later model voltmeters with no success. Did they give you a quote?
earl84 is offline   Reply With Quote
Old 12-20-2016, 03:43 PM   #9
Doug66
I did not get a quote, but will send off anyway and then discuss. I bought a repop tach which was way off. It was replaced by Bros. Trucks and again, way off. Sent it to Williamson and they calibrated and replaced the spring. Dead on now. Price was $69 incl. return shipping to FL. Great folks.
Old 12-20-2016, 06:32 PM   #10
duallyjams
duallyjams's Avatar
http://www.williamsons.com/Home_Page.php
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
