Old 12-20-2016, 07:17 PM   #1
Captmatt
Anyone know if this part is available ?
This is the plastic spacer/bearing that goes on the bottom of the shifter base on a 64 steering column. It keeps the inner shaft center and supported at the top of the column. I have checked several catalogs etc with no luck. Any help appreciated.
Captmatt is offline   Reply With Quote
Old 12-20-2016, 07:18 PM   #2
Captmatt
Re: Anyone know if this part is available ?
Another photo
Old 12-20-2016, 08:53 PM   #3
AcampoDave
AcampoDave's Avatar
Try these guys www.steeringcolumnservices.com When I needed a rare part for a Caddy tilt/tele column, they had it.
AcampoDave is offline   Reply With Quote
Old 12-20-2016, 10:49 PM   #4
Johns66
Is this on a 3 speed manual shift or automatic?
Johns66 is offline   Reply With Quote
Old 12-21-2016, 06:01 PM   #5
Captmatt
3 speed manual, I think the auto columns have the same part
Old 12-21-2016, 06:18 PM   #6
Captmatt
Thanks for the info, sent them a message with a photo. Fingers crossed !!
Old 12-21-2016, 09:56 PM   #7
Kenfuzed
Kenfuzed's Avatar
Maybe that is specific to the manual shift because I don't remember seeing that in my 66 w/auto. I just bought a new turn signal assembly and it has the bearing which supports the steering shaft.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-22-2016, 06:45 PM   #8
Captmatt
Thanks for that info. Good web site but they told me they do not have the part I'm looking for. Darn it
Old 12-22-2016, 06:50 PM   #9
Captmatt
Copy that, I have a upper shaft bearing . The part I'm seeking supports the inner shifter tube. With out the part there is serious play and wobble in the steering column. It's a plastic part and I'm sure they get brittle and break over time. Thanks for the reply
Old 12-22-2016, 11:28 PM   #10
luvbowties
luvbowties's Avatar
Smile Re: Anyone know if this part is available ?
Check suppliers for horn button and turn signal parts.
Sam
luvbowties is offline   Reply With Quote
Old 12-23-2016, 12:22 AM   #11
LT1 Burb
LT1 Burb's Avatar
I've taken a few columns apart and never seen that part there, something doesn't look right.
LT1 Burb is offline   Reply With Quote
Old 12-23-2016, 02:08 AM   #12
Kenfuzed
Kenfuzed's Avatar
Comparing this exploded view to your part I don't see where there would be a plastic spacer or washer. The only washers are the one above and below but neither are plastic.
The only lower gear shift washer I've seen looks like this:
http://www.ebay.com/itm/NOS-Chevy-Pa...-/271548781208
Enjoying the ride!
Old 12-23-2016, 10:04 AM   #13
LT1 Burb
LT1 Burb's Avatar
That's what I think it is supposed to be to, then the screw holds it in place.
Old 12-23-2016, 07:55 PM   #14
Captmatt
So here is another photo of the part in place. Thank you lugnutz65 for the photo. It goes just above the part that you are showing. The part is also visible in a couple of other photos that lugnutz65 has of a disassembled column. It's the yellowish plastic part in the photo.
Regardless , sounds like this part is not made anymore. Thanks for all the imput.
Old 12-28-2016, 11:16 PM   #15
luvbowties
luvbowties's Avatar
I think we all are looking too high--the washer(bearing/spacer?) he needs is the part pictured as number (9)--3756174; this is what GM calls a "washer assembly" in the exploded view. It looks like it acts as a spacer/bushing between the inner and outer tubes.
Correct me if I am wrong; use that reference/with picture in placing an order if you think this is correct.
Good luck,
Sam
Old 12-28-2016, 11:32 PM   #16
luvbowties
luvbowties's Avatar
Try these:
>>>> http://www.steeringcolumnservices.co...earing-kit.php <<
>>>> http://www.steeringcolumnservices.co...earing-kit.php <<<<
Sam
