Old 12-20-2016, 09:03 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
250I6 swap to 283V8
Finally swapping my son's 1963 C10 -- I6 to a V8...
The I6 currently in the truck is a 250ci(not the original motor), it has a TH350 trans.
Any advance info or advice will be greatly appreciated.
I've read that the I6 motor mount has 3 pieces and if you remove the center piece, it will bolt up directly to the V8, with no need to buy new motor mounts. Is this correct?
Will the trans have to be moved forward or back, or will it remain in the same position? I'm just wanted to know whether or not we'll need to end up having the driveshaft lengthened/shortened.
Is there anything else that I need to be aware of, or on the look out for during the swap?
thanks
'63MurderTruck is offline   Reply With Quote
Old 12-20-2016, 09:22 PM   #2
padresag
Re: 250I6 swap to 283V8
what you read is correct and should remain in that position
ron
padresag is offline   Reply With Quote
Old 12-20-2016, 09:57 PM   #3
'63MurderTruck
great news!!!
ron
Old 12-20-2016, 10:09 PM   #4
'63MurderTruck
The 283 is out of my 1957 Chevrolet Belair, it has a standard trans... so, I'll need to use the FLEXPLATE from the I6 if it's interchangeable, because the 283 will be paired with a TH350.
Are the I6 and the V8 FLEXPLATES interchangeable?
Old 12-20-2016, 10:40 PM   #5
65 GMC
Flex plate should interchange along with the starter.
65 GMC is offline   Reply With Quote
Old 12-20-2016, 10:49 PM   #6
'63MurderTruck
More good news!!! Thanks
Old 12-20-2016, 11:32 PM   #7
lumpy63
lumpy63's Avatar
If your 283 is truly from a 57 chevy it will not have provisions for side mounts. Look on the sides of the engine block for the mounting bosses. Chevy did not start using the side mounts until 1958.
lumpy63 is offline   Reply With Quote
Old 12-20-2016, 11:52 PM   #8
'63MurderTruck
Good catch.
Evidently the 283 was not original to my '57, because it DOES have the side motor mount provisions.
Old 12-21-2016, 12:04 AM   #9
lumpy63
lumpy63's Avatar
Good news
