Old 12-21-2016, 12:41 PM   #1
Shugalou
Shugalou's Avatar
1 quart of Por 15 enough?
A distributor close to me has 2 quarts left but they are $67/quart. Would one be enough to do the chassis and other parts? I'd hate to buy more than I need.
I was told one quart will cover 96/sq ft.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 12-21-2016, 01:08 PM   #2
SkinnyG
SkinnyG's Avatar
Re: 1 quart of Por 15 enough?
You want to apply it quite thin, and you want two coats. I think you'll be fine with a quart.
Then again, you will probably have a use for the other quart at SOME time in your life. If this is a good price, get it.
The stuff starts to cure once you open the can, so some people poke a wee hole in the side of the can, pour out what they need, then fill the can with MIG gas through the hole, and close it with a large wood screw.
I haven't gone that far, but I have used similar paint that certainly gets thicker in the can over short time.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-21-2016, 01:38 PM   #3
CSHADES
CSHADES's Avatar
I know 1 quart wasn't enough to do my chassis inside and outside the channel
CSHADES is offline   Reply With Quote
Old 12-21-2016, 06:58 PM   #4
Shugalou
Shugalou's Avatar
Thanks for the response and good tip about putting the gas in the can.
The guy at the store said you could also pour into a ziplock bag.
At Napa they have a similar product called Dom 16. Supposed to be the same thing at half the price. I'll try it out on my tank brackets soon.
Old 12-23-2016, 12:53 PM   #5
Low69CST
2 quarts wasn't even close for me. $67 sounds a little high. Check Amazon and summit for cheaper prices. Also it set up very quickly so do as much at a time as possible.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 12-23-2016, 01:08 PM   #6
Shugalou
Shugalou's Avatar
Low,
That is our Canadian prefered pricing Amazon.ca has it for 52 and free shipping so that's better - good suggestion.
Thanks for the heads up on setting up quickly.
Old 12-23-2016, 01:27 PM   #7
Low69CST
Also if it dries on your skin it will not come off. It won't come off anything when it dries. So cover everything up good. We kept an old roll of plastic to lay over the floor. We painted everything we could with it.
Old 12-23-2016, 04:08 PM   #8
Shugalou
Shugalou's Avatar
Yeah I've heard it stick to everything and is very bad for you overall. When I use I'll have the garage door open.
