anybody cut a 69 grille and add a 71 insert?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
Re: anybody cut a 69 grille and add a 71 insert?
I ask because I have a 69 grille and the center is bent way past straightening and I like the 71/72 grille just as much, maybe better. I figure if I cut the center out and buy the $80 insert. The original surround would shine up nice too.
I believe that works fine. I was going to say just buy the 71-72 because the earlier grill more valuable, but if it's already damaged, go for it.
One thing to think about....the 69-70 have the bowtie on the hood above the grill and the 71-72 have it on the grill. I have seen a few 69-70 trucks with the 71-72 grill sporting two emblems. One on the hood and right below it on the grill.....in my opinion they dont look good with both emblems. You may be able to get a 71-72 grill that doesn't have a spot for the bowtie or take the one off the hood and patch the holes?
laying low
![]() Join Date: Mar 2001
You would need to swap the bumper too for the parking/turn lamps or find a way to mount them behind the 71 grille insert.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
thanks guys! Didn't even think about the emblem issue or the parking light issue. Its all in pieces ...
might as well try it though as the grille is twisted and bend badly in the center
maybe I can buy a repop with a emblem delete or something
or simply take the hood emblem off and shave the holes
#9 | |
