Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 12-21-2016, 09:12 PM   #1
randy500
Suburban body and frame cuts, starting at $35 plus shipping
See my parting out ad on the 72 suburban, I have a Stihl cutoff saw and am ready to cut this thing up so put in your request as it wont be here long.
I am using the cowl, the floor and the A, B and C pillars along with the front of the roof for a crew cab build. Not using the frame. I also have a couple truck cabs and beds for cuts.
randy500 is offline   Reply With Quote
Old 12-23-2016, 05:55 PM   #2
notchbackgta
Re: Suburban body and frame cuts, starting at $35 plus shipping
I am wanting a part of the interior rail under the back window so I can delete the rear tire carrier part of the rail, and I need the long interior trim on the LH side that the panels go into so I can use on the RH side. I could also use the frame horns on the back, I can measure the amount. I also need the 3rd position body mounts off the frame, I will take all three positions, but I really only need the 3rd, by the rear wheels.
notchbackgta is offline   Reply With Quote
Old 12-24-2016, 02:06 PM   #3
randy500
I have the long trim piece, $25 plus shipping. I can do the spare tire piece cut out for $35. Frame horns look good. Not sure on the body mount positions, they look fine, not sure which ones you need. I will look and get a picture posted
Old 12-24-2016, 03:19 PM   #4
notchbackgta
That all sounds great. Let me know and I can pay for it all
Old 12-27-2016, 10:28 PM   #5
randy500
Here is some pics of trim piece from drivers side, its a bit rusty, side will clean up and top probably not. Tell me the length of the cut you want to fill the spare tire indentation.
Once I get the cut length I will cut that out and figure out shipping for you. Send me your zip code too.
Old 12-28-2016, 05:43 PM   #6
notchbackgta
I'll just be painting that piece of trim anyway, so the rust isn't a big concern as long as it isn't real bad, juts looks like surface rust though.
24" of the window rail should be more than enough. I would want all the way up to the window channel, but you can drill out the spot welds so you don't have to cut through the outside, if you want
Also, the last 24" of each frame horns should be what I need to add to a truck frame. And those 3rd position mounts if I can get them.
This is the 3rd position mount I am referring to
Old 12-28-2016, 07:56 PM   #7
randy500
I understand on the 3rd mount, it has 3 rivets, one on each side and one on the top of the frame rail.
The trim piece is just light surface rust which damage the chrome on the top.
Where in relation to the last body mount do you want the frame rails? Just before coming from the bumper to the mount?
Interior side panel, 24" with the window pinch rail, $35
3rd Body mounts, pair for $70
Interior, Dvr side rear chrome trim piece, $25
Frame rail, both sides for $70
Total of $200, I will guess shipping at $40, lets go actual on the shipping, if it is less I will refund you the difference, if more, I will let you know, does that sound fair? T
he frame cuts are not easy since the gas tank has to be removed and I will be on my back. The body mount isn't easy either, think I will have to cut a hole through the plywood floor with a skill saw while trying to avoid metal parts.
My paypal is randy501@outlook.com. Please put a note in there as to what you are buying and your screen name from here. I can get all that cut out by next weekend.
PM me your name and phone if you want and I will text you pics as I cut that stuff out.
Old 12-29-2016, 12:44 PM   #8
Heliarcn
I'm looking for a 12" section of both frame rails that starts 18" from the front. So, if you measure back 18" from the front of the frame, that would be the starting point and I need the next 12" of the frame. Both sides.
Bret
1972 Chevy Suburban
1976 Blazer
Heliarcn is offline   Reply With Quote
Old 12-29-2016, 02:00 PM   #9
randy500
Hi,
Nice picture for description. I will cut that for you and do it for $35 ea piece with estimated shipping of $35. I will refund you the difference if less and request more if it costs more. How soon do you need it?
Those sections appear to get into where the front crossmember bolts up, am I correct? You need it for a 1/2ton right?
Just curious, why do you need that?
Old 12-29-2016, 02:34 PM   #10
Heliarcn
Hi,
Yes, I need this for a 1/2 ton. The section I need is right in front of the crossmember bolts. I installed Porterbuilt front suspension on my frame which requires you to notch the frame for the steering rack. I've decided to go a different route and I need to replace the areas of the frame that are notched as you can see in the picture. I'm good with the price. Can you PM me PayPal info? I would like to have these within the next 2 weeks.
Bret
1972 Chevy Suburban
1976 Blazer
Old 12-29-2016, 02:58 PM   #11
randy500
Ok, I will get you the 1/2 ton frame pieces, I will ship by next Friday, likely will cut this weekend and ship sooner, sending pm now
Old 01-17-2017, 10:53 PM   #12
Paintpro
Paintpro's Avatar
Do you have the rear frame horns yet & if you do can you get me a picture of them. Thanks
Paintpro is offline   Reply With Quote
Old 01-17-2017, 11:23 PM   #13
randy500
I did cut those rear frame horns off for another person, he hasn't paid for them yet, let me check with him on that.
Old 01-18-2017, 08:42 AM   #14
Paintpro
Paintpro's Avatar
Ok THanks
Old 01-18-2017, 07:43 PM   #15
notchbackgta
Hey, I lost our previous communication, i don't remember how we were talking. I am ready to pay for all the stuff though.
Old 01-18-2017, 09:13 PM   #16
randy500
I will send you a text.
Old 01-19-2017, 01:12 PM   #17
Heliarcn
Received the frame sections. They are the exact section I need. Thank you!
Bret
1972 Chevy Suburban
1976 Blazer
Old 01-20-2017, 12:45 AM   #18
randy500
Great! and your welcome, Happy I got you what you needed.
Old 03-15-2017, 09:51 PM   #19
DarkKnightWong
Hi
Do you have the lower cab front corner where the front fender bolts through ?
I need the driver side.
I attached a picture I found on here as an example of what I need
I'm in GA 30338
Allen
DarkKnightWong is offline   Reply With Quote
Old 03-15-2017, 09:58 PM   #20
randy500
I do have one of those and it would be in about the same condition as the one in the picture, $35 plus shipping
Old 08-12-2017, 08:49 PM   #21
Vero67
Looking for truck cab cuts, outside above the doors both sides from the back of the a pillar, to where it starts to curve down. From where the weatherstrip attaches to the outside where the driprail attaches. Shipped to 32968.
Vero67 is offline   Reply With Quote
Old 11-27-2017, 09:37 PM   #22
THECRAZYKIDJR
Sorry, just noticed dates of these posts...
Would you have any burbs sheet metal available...
See below.
Looking for the sheet metal sill under the barn doors from pillar to pillar.
Jim
JIM PARKER
GLENBURN, MAINE
69 BURB 4WD - 307/4SPD/YELLOW
69 BLAZER (ORANGE / 35" SUPER SWAMPERS)
1970 CUSTOM-10
THECRAZYKIDJR is offline   Reply With Quote
Old 11-27-2017, 10:47 PM   #23
randy500
See below.
Jim
I don't have that or much else left from the burb. Thanks for inquiring though.
Old 01-27-2018, 09:20 PM   #24
carryall
Do you have this section? Name:  image.jpeg
1967 Chevy Truck
1969 Chevy Panel Truck work in progress
1971 GMC 1500 all orginal
1972 Chevy Suburban brought from orignal owner
1984 Dodge Rampage 45,000 original miles
1992 Dodge D150
1994 Buick Roadmaster (LT1 Engine)
2000 Chevy Stepside Z71
2008 Honda Element
carryall is offline   Reply With Quote
Old 01-27-2018, 10:31 PM   #25
randy500
Originally Posted by carryall View Post
Do you have this section? Attachment 1745045
Sorry, no, the body was scrapped.
