1972 trailing arm crossmember
hey guys, I have a 72 c10 longbed and I bought a trailing arm crossmember from LMC, essentially it came from cpp, but I'm hearing that this wont work with a long bed truck , is this true and why?
![]() Join Date: Aug 2004
Re: 1972 trailing arm crossmember
It should be the same for long or short.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Daily Driver
the long beds have the carrier bearing there for the driveshaft. swb do not have the provisions for the bearing for the two piece driveshafts. look at pbfab.com and see their 2 different photos for options for a better understanding of what im getting at.
nitrous...the equal opportunity destroyer. |
Yes it will work with a long wheelbase. Both short wheelbase and long wheelbase trucks came from the factory with a two piece driveshaft and carrier bearing, although there are at least three different types of carrier bearings. If you plan to keep your two piece driveshaft you need the carrier bearing bracket that bolts to the crossmember (which is mentioned on their website).
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#6 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Many short beds also have carrier bearings.
okay awesome thanks guys!
