Old 12-22-2016, 12:46 AM   #1
wpavlis
Weekend Brake job
So, my rear brakes were not working on the 68. It's been a while since I worked on drum brakes, but seeing as how this truck has 4 there is no time like the present. Everything went fine while tearing down the drivers side. I pulled these out of the wheel cylinders. Does anyone know where I can get replacements? I suppose I could soak in evaporust and paint, but I am worried the paint would wear off over time. I think they are called wheel cylinder push pins or something like that. I found some on ebay, but that's it. Thanks!Name:  wheel push pins.jpg
wpavlis is offline   Reply With Quote
Old 12-22-2016, 01:02 AM   #2
geezer#99
geezer#99's Avatar
Re: Weekend Brake job
Clean them up and use them again. No paint needed.
Clean with some scotchbright pads or steel wool.
geezer#99 is online now   Reply With Quote
Old 12-22-2016, 08:42 AM   #3
wpavlis
Cool, I was hoping that's all it would take.
Old 12-22-2016, 01:14 PM   #4
demian5
demian5's Avatar
These last forever unless they are on a 1 ton truck and a brake hold down spring lets go and mangles them beyond recognition.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-22-2016, 01:20 PM   #5
berch 69GMC
berch 69GMC's Avatar
Rock Auto
berch 69GMC is offline   Reply With Quote
Old 12-22-2016, 03:39 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I powder coated mine...
j/k... no I didn't.
Do as geezer said and reuse them.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-22-2016, 08:11 PM   #7
TexasLS1
TexasLS1's Avatar
j/k... no I didn't.
Gary
Haha! I would not hate on you if you did powder coat them, I know how OCD we all are here!
I concur, just reuse them. Soak them in vinegar, clean them with scotch brite, flash them with paint if you want. They're gonna get dusty and you won't see them anyway, though.
TexasLS1 is offline   Reply With Quote
Old 12-22-2016, 08:26 PM   #8
leftybass209
leftybass209's Avatar
You could paint them if you're just that adamant about it, but they're just fine with a wire brush up and reinstall.
leftybass209 is offline   Reply With Quote
