Active Member
![]() Join Date: Sep 2013
What Trans did I have?
This is my first heavy hauler and I'm not too familiar with them. It's a 1969 C6500. Picked it up for $300 and was gonna strip it, but now seeing everyone's builds, I want to build it now lol my question is, what kind of manual transmission was in here? The owner said it had a 427 tall deck bbc. I have a 366 tall deck that I was going to put in it, but was also wondering can I use a TH400? Will the th400 spin this huge rear axle lol thanks, Jon
-87EA-4E0B3437D7B7_zpsmqfqgfcp.jpg.html] [/URL]
1972 GMC C2500 Tow Rig project 1972 C10 Air Bag project 1967 C10 Drag Truck project 1967 GMC Patina Special project 1968 C10 I have no clue what to do with project 1969 GMC C6500 I wish I had more money project 1986 K10 I have too many damn projects |
#2 | |
Re: What Trans did I have?
Great project, I'm glad to see another one rescued. -Richard
I may have too many Chevys... Is that possible? ![]() 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
only thing I might suggest is a th475 its the same but different gear units inside straight cut theeth if I recall. used a lot on big motor home chassis .
but as said even a good prepped / remaned th400 should hold up just fine other than building mounts and driveline for it . if you were closer I could get you a smoking deal on a real low mile gmc V6 with tranny and even a spare tranny with a pto on it from the same vintage truck if you just needed to put around with it . all still in the frame with rosted body on it . should still fire up with fresh batt . last run this summer .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Active Member
Thanks guys. Yeah I had a feeling about making a Trans mount which is no problem. As for the engine mount I found the original one that bolts up like a sbc in a 57 Chevy. Mocked it up already with the 366 and looks like it will work.
| Bookmarks |
