Old 12-22-2016, 10:31 AM   #1
Isaiah92260
Isaiah92260's Avatar
E-Braje cable snapped. How do I replace?
I have a 63. My parking brake cable snapped lastnight when I was parking in my garage. I had to disengage the cable with a crowbar to push back the bracket that pulls the cables.
I've never replaced the main cable before. Is there a certain way it needs to be done? Has anyone done it before and can walk me through it? What length cable am I looking for a 63'? Thank you
Isaiah92260 is offline   Reply With Quote
Old 12-22-2016, 10:48 AM   #2
PGSigns
PGSigns's Avatar
Re: E-Braje cable snapped. How do I replace?
What are you calling the main cable? The one from the handle to the lever under the truck? LMC has the 63 cables. Its not bad at all to change them. If you use it often may be a good time to check them all and replace what ever it needs while you have it apart.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-22-2016, 10:56 AM   #3
Isaiah92260
Jimmy
The cable from the lever to the bracket. Okay awesome, thank you I'll look at LMC
Old 12-22-2016, 11:16 AM   #4
PGSigns
PGSigns's Avatar
That one is really easy. A couple of pins and a couple of clips and it will come right out. If you order a new cable order the rubber gromet for the floor. Old ones don't tent to be much good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-22-2016, 12:40 PM   #5
vince1
It is also common for the cables going back to the brake shoes to seize up.
vince1 is offline   Reply With Quote
