Old 12-22-2016, 11:07 AM   #1
Alanj80
Raised wheel tubs
Hey guys I'm new to the forum,thanks for the add. I was wondering if anyone had any links or info on raising the stock wheel tubs in the rear. I'm building an 87 short bed, bagged with extensive rear set up, ridetech up front and a 5.3 setup. Thanks
Alanj80 is offline   Reply With Quote
Old 12-23-2016, 12:50 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Raised wheel tubs
Are you raising the bed floor as well?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-23-2016, 03:15 AM   #3
andrewmp6
http://www.sloshtubz.net/ hills website is acting up for me but http://67-72chevytrucks.com/vboard/s...d.php?t=465046
andrewmp6 is offline   Reply With Quote
Old 12-23-2016, 10:32 AM   #4
Alanj80
No I'm not raising the bed floor, just trying to reuse the factory tubs.
Old 12-26-2016, 12:34 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
How tall of a tire are you running? If your not raising the floor and your not cutting your bed, the pumpkin will hit before you need taller tubs.
Regardless, unless you have the ability to weld a sectioned tub your best bet is look at Slosh Tubz
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-26-2016, 12:51 PM   #6
UKNOWME
UKNOWME's Avatar
He doesn't make a taller tub for the rear, does he? I only see wider tub for the 60-66 model.
1964 Chevy c10
Old 12-26-2016, 08:25 PM   #7
andrewmp6
Hills does its for the 67-72 trucks but could be made to work.Or if you don't care if it looks factory ish http://www.avsontheweb.com/notch-covers/
Old 12-26-2016, 08:29 PM   #8
UKNOWME
UKNOWME's Avatar
Even so. I agree with Ken. If he's not raising the floor what is he gonna gain from it? I'm not being a smart ass. I'm sure I'm missing something.
1964 Chevy c10
Old 12-26-2016, 08:39 PM   #9
Alanj80
Sorry for the confusion guys, I'm not raising the floor but it is cutout for the notch to come threw the floor, I already have that cover built. I'm just looking ideas for the wheel tubs. Thanks for the responses guys.
Old 12-26-2016, 08:49 PM   #10
UKNOWME
UKNOWME's Avatar
Will the tire hit the top of the rear tubs when you're aired out?
1964 Chevy c10
Old 12-26-2016, 08:51 PM   #11
Alanj80
Yes, I'll try and get a pic uploaded. I'm going to try and just add 4 inches to the factory tubs to make them taller.
Old 12-27-2016, 11:06 AM   #12
SCOTI
SCOTI's Avatar
Raise the attachment points of the tubs on the inner bedside however much higher you need. Drill new holes & use nutserts/rivetnuts to get it done. Bolt the tubs in. Then make filler pieces to fill the gap between the vertical portion of the tub flange @ the new higher location to the original floor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
