12-22-2016, 08:42 PM | #1 |
Replacing Spindles - Lower Control Arm Issue
I'm putting 2.5" drop spindles and disc brakes on my son's '63 C10...
I've got the old drum brakes off. I've removed the 2 castle nuts from the spindle as well as removed the shock... I have a jack under the lower control arm. My problem is this.. i can't get the lower control arm to free up and 'drop'. I've tried using my tie rod separator by prying it in and it still won't drop. Any advice? Thanks |
12-22-2016, 09:08 PM | #2 |
Re: Replacing Spindles - Lower Control Arm Issue
Hey Murder, I just hit the spindel with a dead blow hammer or small sledge hammer at the end where the lower ball joint goes through. should pop off after a few good hits. good luck
12-22-2016, 09:13 PM | #3 |
Leave the nuts on it with about a 1/4" gap top and bottom. Set the frame on a jack stand and let the pressure off the lower control arm. Then hit the spindle with a big hammer and it all will come right apart. Let the spring do a lot of the work. Then take the weight with the jack.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-22-2016, 09:37 PM | #4 | |
Loosen the Castle nut but do not remove it. Whack the top of the castle nut, You will here it pop and the castle nut will stop it from coming apart.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
12-23-2016, 01:49 PM | #5 |
do what pgsigns told you to do hit the spindle on the side where the ball joint go's threw it if you start beating on the castle nut you will tear up your ball joint threads
12-26-2016, 03:11 PM | #6 | |
I have tried, and tried this method on BOTH sides and neither will pop off.
I've done this before on my '57 Belair and it worked great. I have no idea why this isn't working. I have no clue how to get these damn spindles off. Frustrated. Quote:
12-26-2016, 04:27 PM | #7 |
*UPDATE*
Finally got it. |
12-26-2016, 04:28 PM | #8 |
Moderator
Didnt have a big enough hammer?
12-26-2016, 04:28 PM | #9 |
I had the same issue with my right side. I went to HARBOR FREIGHT
and bought this : http://www.harborfreight.com/3-4-qua...tor-99849.html it came out with a bang ! ( and yes leave the castle nut on !)
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-26-2016, 04:32 PM | #10 |
12-26-2016, 04:35 PM | #11 |
12-26-2016, 06:29 PM | #12 |
thats one way in doing that ....
dont want to hear excuses, i want to hear solution(s) |
12-26-2016, 09:29 PM | #13 |
