Old 12-23-2016, 01:07 AM   #1
IXLR82FAST4U
2" lowering blocks
hey dudes, I lowered my 72 pick up truck and used 2.5" spindles, 2 inch drop springs in the front and 3" drop springs in the rear, it lowered quit a bit but I dont like the way it stands so I was thinking of using 2 inch lowering blocks in the rear to level it out, when I look htem up they have a foot note that says you cant use 15" wheels . does anyone know why and if it does hit then where?
IXLR82FAST4U is offline   Reply With Quote
Old 12-23-2016, 01:40 AM   #2
Trevor
Trevor's Avatar
Re: 2" lowering blocks
No parts hit anything on the truck but, it creates a safety issue and it's therefore illegal in pretty much every jurisdiction on the planet.
With 15" wheels, installing 2" lowering blocks puts the bottom side/surface of the trailing arms below the bottom of the rim.
1-1/2" blocks are maximum or you'll have to go bigger diameter wheels or of course 4" drop springs.
It's a safety issue should you ever have a tire blow, the trailing arm would contact the pavement and not the rim, and when that happens you skid uncontrollably like a skateboard on ice ...
Trevor is offline   Reply With Quote
Old 12-23-2016, 01:48 AM   #3
IXLR82FAST4U
good info thanks, ill be doing bigger wheels then.
Old 12-23-2016, 10:16 AM   #4
67 chevelle
67 chevelle's Avatar
I dont like blocks , they can be problematic , sliding around and making "clunking" noises , springs are the way to go
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 12-23-2016, 12:39 PM   #5
demian5
demian5's Avatar
Yeah same thing if an airbag blows on a truck that can "lay frame". I've been witness to that.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
