Old 12-23-2016, 05:39 PM   #1
Ramiro0727
American autowire harness 51004
Hello,
I have a American autowire harness 51004 power plus 13. I'm getting ready to wire up my reverse tail lights and I not sure which wire it is. I have only 3 wires that I ran from the harness to the back. I have a yellow, brown and a dark green wire. Did I forget to run the wire for the reverse tail lights?
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 12-23-2016, 05:55 PM   #2
JDL
JDL's Avatar
Re: American autowire harness 51004
yes yellow and green are stop and turn signal and brown is the tail lights
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 12-23-2016, 05:57 PM   #3
Ramiro0727
Which wire is for the reverse tail lights? Do I have to splice into the brown wire?
Old 12-23-2016, 06:16 PM   #4
Ramiro0727
JDL do I connect the light green reverse tail light wires to the brown wire also?
Thanks,
Ramiro
Old 12-23-2016, 06:32 PM   #5
JDL
JDL's Avatar
no they all go to different lights
72 nova project car
Agency Iowa
Old 12-23-2016, 06:46 PM   #6
Ramiro0727
Oh ok. I must check if I forgot to run the reverse tail light wire to the back.
Old 12-23-2016, 07:16 PM   #7
Ramiro0727
I checked all the wires from the harness. I don't see a wire labeled reverse tail light.
Old 12-23-2016, 07:42 PM   #8
JDL
JDL's Avatar
dark green looks like it is right side stop and turn light
yellow is for the left side stop and turn
Brown is for the tail lights
light green is for the back up lights
72 nova project car
Agency Iowa
Old 12-23-2016, 07:46 PM   #9
dfwright
dfwright's Avatar
If the wires are anything like the "classic update" kit, there should be a light green wire to the back also
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-23-2016, 07:50 PM   #10
Ramiro0727
JDL I don't have a light green wire on the harness I have that goes to the rear of the truck. I'm looking at the harness instructions and it don't mention back up light wires. Attached is a picture of the instructions for the rear.
Ramiro
Old 12-23-2016, 07:55 PM   #11
Ramiro0727
Dfwright as far as I can tell. I don't see a light green wire.
Ramiro
Old 12-23-2016, 08:33 PM   #12
JDL
JDL's Avatar
looks like the kit you have does not have wires for the back up lights
72 nova project car
Agency Iowa
Old 12-23-2016, 08:38 PM   #13
Ramiro0727
It sure sounds like it. Might have to call the manufacturer to see what options I have to get a backup light wire of the fuse panel.
