Old 12-23-2016, 08:19 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
No gas?
So the 84 won't start now. It's been sitting for about a month and ran awesome when I parked it. *Murphys law* anyways. One tank is almost empty and the other is 3/4 full. But after a month of sitting the filter went dry *glass filter* and won't get any fuel. I can see the filter flexing when I try to start it so I know it's pumping but no gas!. I tried switching tanks and gauge works showing I'm switching and can hear the switch click over but when I click back to full tank the valve makes a squealing sound. Any ideas?
On a quite night you can hear a ford rust
HotRodScottsdale is offline   Reply With Quote
Old 12-23-2016, 09:09 PM   #2
nonstop
Re: No gas?
Might first try filling the float bowl with gas through the vent and starting it. Sometimes the trucks need a little run time to push gas up to the carb.
nonstop is offline   Reply With Quote
Old 12-24-2016, 01:25 PM   #3
tucsonjwt
Re: No gas?
I saw a trick a tow truck driver use when my 73 broke down on the road. He removed the wing nut from the air cleaner cover and poured a little gas in the hole around the air cleaner threaded stud. The gas will puddle in the small recession around the stud and trickle down into the carburetor. It worked in my case.
Ether sometimes work for old vehicles which have not moved in a while.
tucsonjwt is offline   Reply With Quote
Old 12-24-2016, 03:30 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: No gas?
The float bowl vent on the Rochester Quadrajet is a tube that sticks up above the choke plate on the edge of the air horn.
1-2oz of fuel will fill the float bowl. It'll run for 10-15 seconds on that. That much actual runtime will pull fuel up from the tank if you don't have leaks.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
