12-25-2016, 03:01 PM | #1 |
Vent by passengers feet!
Planning the process of installing interior. There is a vent down by the passengers feet which appears to be operated by a spring loaded gadget. Is this connected to the heater / vent controls(there is a wire attached)? Also have people simply eliminated it when redoing interior? Does it have a an additional function I might be unaware of? Is it an intake for instance and necessary to the heater function??
12-27-2016, 03:24 PM | #2 |
Re: Vent by passengers feet!
still needing a bit of advice on this? Specifically is this vent by the passenger's feet a necessary item for the functioning of the heating systems? I'm planning on a soft top so actual ventilation isn't a concern.
12-27-2016, 04:07 PM | #3 |
I know the pieces fit
I thought they only vented outside air into the passenger compartment. I use mine in the summer, they really do help keep cool with no AC.
12-27-2016, 05:38 PM | #4 |
There is a spring tensioned gadget and a single wire to the actuator. How does this work??
12-29-2016, 12:39 PM | #6 |
It seems to me that the OP is specifically asking about the passenger side vent of a rig with AC, which is considerably different than the manually operated vent found on non-AC trucks and rebuilt in the Restoring Rusty thread.
I've been following this thread because I also have a vent sitting on the floor of my garage that I'm wondering if I'll be able to reassemble. It is vacuum actuated with a fairly complex spring arrangement. I'm worried I may have lost critical parts, so my plan is to head to the junkyard once it warms up a bit and hope that I can find one there to examine.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
12-29-2016, 01:02 PM | #7 | |
12-29-2016, 03:39 PM | #8 |
AAAAH thank you. Yes the existing vent is from the old A/C but that has been dispensed with as I'm going to be running a soft topper and humidity is not an issue here. I'd assume that the manual vent is the same on teh C10/20 and K10/20 trucks from 1975 also that do not have A/C. Guess its another trip to pick n pull. Also if I do that then mine would be available for dispatch thereafter.
