Old 12-25-2016, 08:18 PM   #1
85 K30 dually single cab, 2 1/2 inch lift, who has done it?
Just wondering what lift you used and what type of steering correction you did?
Old 12-25-2016, 08:38 PM   #2
wildwilly4x4
Re: 85 K30 dually single cab, 2 1/2 inch lift, who has done it?
2.5" shouldn't require any steering correction, but to be close to perfect a 2-2.5" drop pitman arm would work great. Don't forget to add in an ORD steering box brace before you crack out the frame. These are almost a must have even for a stock 4x4.
wildwilly4x4 is offline   Reply With Quote
Old 12-25-2016, 09:04 PM   #3
Cool
Old 12-25-2016, 11:35 PM   #4
b454rat
Cheaper and easier, get a block to go under the stock arm. And while there put new bushing and spring kit in...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-26-2016, 12:00 AM   #5
Like this,
http://shop.broncograveyard.com/Dana...9DBhoC5Ufw_wcB
Old 12-26-2016, 09:32 AM   #6
b454rat
Yes. Shop around, thought I saw it somewhere cheaper....
Old 12-26-2016, 06:44 PM   #7
Thanks,
I'm looking at a BDS all spring 2 1/2 lift
Old 01-01-2017, 11:56 PM   #8
nonstop
I had that block on my truck. I HATED it and took it off. It kept loosening up. I tried the drop drag link and couldn't get the steering wheel centered. I have both now sitting in storage. I went with a dropped pitman arm, and it works very well.
nonstop is offline   Reply With Quote
Old 01-02-2017, 10:30 AM   #9
obijuan
The steering block is cheap but it sucks. K30s need the drop pitman arm.
Yes it says for a 4" but k30s have the larger axle tube and perch which make up a little bit.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 01-02-2017, 01:13 PM   #10
sweetk30
sweetk30's Avatar
x2 on drop drag link or spacer block CRAP .
go drop pitman arm .
I have one on a k30 with 3" and it still has a slight down angle and if I had 2.5" it would still be just fine.
bds is top shelf for leaf spring trucks of our style . tuff country #2 . . . skip rough country unless you want the ride of a empty dump truck .
check the bds kit for 56" rear springs NOT 52" rear . k30 needs the 56"
also splurge on bilstein shocks . tons of guys going with them on our leaf spring trucks these days and loving them .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-02-2017, 06:24 PM   #11
obijuan
This is 4" on my k30. 2.5 is even better probably
Old 01-04-2017, 08:51 PM   #12
Thanks again for all the info, you guys are top notch!
Old 01-11-2017, 09:32 AM   #13
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I'm with the others, go ahead for a drop pitman arm. I have 4" Tuff Country springs up front, the rear is stock. I also have the ORD greaseable shackles and Zone OffRoad's sway bar links.
DSC09872 by Garrett, on Flickr
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
