Old 12-26-2016, 07:08 PM   #1
Isaiah92260
Isaiah92260's Avatar
Brake lamp issue
Was told my tail lights don't appear when stopping. Checked all my connections with a test lamp. Fuses are good, even replaced them just to do it. Brake switch is responsive. But when pressing the brake pedal, no power coming from the black power wire. When I turn on the light switch. I got rear lights and power running through the black wire. Brake lights just don't work at all. Can't figure out why?
I have a 63 c10. Please share some advice or expletive. This is my daily. Thanks !
Isaiah92260 is offline   Reply With Quote
Old 12-26-2016, 07:25 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Brake lamp issue
Isaiah, see if this helps
http://6066gmcguy.com/Electrical-01.html
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-26-2016, 09:25 PM   #3
PGSigns
PGSigns's Avatar
Have you got turn signals? The brake and running lights wont be on the same wire. Put a ground wire on the bed to the frame and I also ground my tail light housings to the bed.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-26-2016, 09:43 PM   #4
jtrichard
If you have rear turn signals L and R then the problem is most likely in the turn switch BUT can be from brake switch to turn switch or bad grounds
jtrichard is offline   Reply With Quote
